ā12-20-2017 01:13 PM - edited ā03-05-2019 09:40 AM
Need help with 4G LTE configuration on IR809 AT&T router. I am totaly new to this
ā12-21-2017 01:17 AM
below is a sample configuration (important 4G related lines in bold). See how far you get, and let us know:
boot-start-marker
boot system flash:/ir800-universalk9-mz.SPA.156-3.M2
boot system flash ir800-universalk9-mz.SPA.156-3.M2
boot-end-marker
chat-script lte "" "AT!CALL" TIMEOUT 60 "OK"
controller Cellular 0
lte sim data-profile 1 attach-profile 1 slot 0
lte sim max-retry 0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
interface Cellular0
no ip address
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
async mode interactive
interface Cellular1
no ip address
encapsulation slip
dialer-list 1 protocol ip permit
line con 0
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
modem InOut
no exec
transport preferred none
transport output none
line 8
no exec
transport preferred lat pad telnet rlogin lapb-ta mop udptn v120 ssh
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line 1/3 1/6
stopbits 1
ā12-21-2017 05:53 AM
Thanks, i will let you know.
ā12-21-2017 07:15 AM
At present this is what I have.
Current configuration : 2397 bytes
version 15.6
hostname IR800
boot-start-marker
boot-end-marker
enable secret 5 $1$ZHUA$jGYnfnZnRrQejLXQ3Ubj8.
enable password detek1
no aaa new-model
ethernet lmi ce
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid IR809G-LTE-NA-K9 sn JMX2052X06X
redundancy
lte sim max-retry 20
interface GigabitEthernet0
ip address 172.1.2.3 255.255.0.0
duplex auto
speed auto
no mop enabled
interface GigabitEthernet1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet2
no ip address
shutdown
duplex auto
speed auto
interface Cellular0
ip address negotiated
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface Cellular1
no ip address
encapsulation slip
interface Async0
no ip address
encapsulation scada
interface Async1
no ip address
encapsulation scada
interface Dialer1
encapsulation slip
dialer pool 1
dialer idle-timeout 30
dialer string lte
dialer-group 1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 2 interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
dialer-list 1 protocol ip list 1
ipv6 ioam timestamp
snmp-server community public RO
access-list 1 permit any
control-plane
line con 0
script dialer lte
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
no exec
line 8
no exec
line 1/3 1/6
stopbits 1
line vty 0 4
password detek2
login
transport input none
no scheduler max-task-time
end
ā12-21-2017 07:42 AM
below is the sanitized config. After you are finished configuring, issue the command 'show cellular 0 profile'.
version 15.6
hostname IR800
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip cef
no ipv6 cef
redundancy
ip nat inside
duplex auto
speed auto
no mop enabled
interface Cellular0
encapsulation slip
dialer in-band
dialer pool-member 1
dialer-group 1
interface Dialer1
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer pool 1
dialer string lte
dialer-group 1
no ip http server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit 172.1.0.0 0.0.255.255
ipv6 ioam timestamp
control-plane
line con 0
script dialer lte
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
no exec
line 8
no exec
line 1/3 1/6
stopbits 1
line vty 0 4
password detek2
login
end
ā12-27-2017 10:23 AM
Hi George,
I get this.
IR800(config-if)#dialer pool-member 1
%Remove Legacy DDR Configuration first
IR800(config-if)#exit
IR800(config)#default interface cellular 0
Interface Cellular0 set to default configuration
IR800(config)#interface cellular 0
IR800(config-if)#ip address negotiated
IR800(config-if)#encapsulation slip
%Configure a "dialer in-band" first.
IR800(config-if)#dialer in-band
IR800(config-if)#dialer-group 1
%Remove Dialer Profile Configuration first
IR800(config-if)#
this is driving me crazy.
ā12-27-2017 10:27 AM
erase the entire configuration and start over again, that is probably a lot faster than messing with that message:
IR800#wr erase
ā12-27-2017 10:30 AM
Hi George,
would it be better if i give you access to the computer I am working on and you do the configuration will I follow along. we can us TeamViewer for this purpose.
ā12-28-2017 09:42 AM
is this something I have to resolve?
IR800#cellular 0 lte plmn select manual 310 410 lte power-cycle
IR800#
*Dec 28 17:42:04.653: %CELLWAN-4-MANUAL_PLMN_SELECTION_FAILED: Manual/Force PLM
N Selection Failed. Error[1037]
ā12-21-2017 09:32 AM
Hi, i also added the info after a show cell 0 all command.
Hardware Information
Modem Firmware Version = SWI9X15C_05.05.58.00
Modem Firmware built = 2015/03/04 21:30:23
Hardware Version = 1.0
Device Model ID: MC7354
Package Identifier ID: 1102037_9903214_MC7354_05.05.58.00_00_Cisco_005.009_000
International Mobile Subscriber Identity (IMSI) =
International Mobile Equipment Identity (IMEI) = 356734060428194
Integrated Circuit Card ID (ICCID) = 89014104279512334343
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) =
Modem Status = Online
Current Modem Temperature = 0 deg C
PRI SKU ID = 9903214, PRI version = 005.025, Carrier = Generic
Profile Information
Profile 1 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = Broadband
Authentication = None
* - Default profile
** - LTE attach profile
Configured default profile for active SIM 0 is profile 1.
Data Connection Information
Profile 1, Packet Session Status = INACTIVE
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current System Time = Sun Jan 6 0:45:59 1980
Current Service Status = No service
Current Service = Unknown
Current Roaming Status = Home
Network Selection Mode = Automatic
Network =
Mobile Country Code (MCC) = 310
Mobile Network Code (MNC) = 410
Packet switch domain(PS) state = Not attached
Location Area Code (LAC) = 0
Cell ID = 0
Radio Information
Radio power mode = online
Channel Number = 0
Current Band = Unknown
Current RSSI(RSCP) = -90 dBm
Current ECIO = -13 dBm
Primary Scrambling Code = 0x100
Radio Access Technology(RAT) Preference = AUTO
Radio Access Technology(RAT) Selected = UMTS
Modem Security Information
Active SIM = 0
SIM switchover attempts = 0
Card Holder Verification (CHV1) = Enabled
SIM Status = Locked
SIM User Operation Required = Enter CHV1
Number of CHV1 Retries remaining = 3
GPS Information
GPS Info
GPS Feature: enabled
GPS Port Selected: Dedicated GPS port
GPS Status: GPS location cannot be acquired
GPS auto tracking status: unknown
GPS auto tracking config: disabled
GPS Mode Configured: not configured/unknown
Last Location Fix Error: Offline [0x0]
SMS Information
SMS Service is not available
Error Information
This command is not supported on this platform.
Modem Crashdump Information
WIC type is 00
Cellular0 is MC73xx based
Modem crashdump logging: off
ā12-21-2017 09:49 AM
Hi, I get this if I want to change the dialer pool.
IR800(config-if)#
ā12-21-2017 11:43 AM
default the cellular interface and enter everything again:
ā12-22-2017 09:45 AM - edited ā12-22-2017 09:50 AM
You config looks good but there are a few things that are missing, and some other things that aren't required.
Here is the Cell 0 config we use:
! interface Cellular0 ip address negotiated ip nat outside ip virtual-reassembly in encapsulation slip dialer in-band dialer idle-timeout 0 dialer enable-timeout 6 dialer string lte dialer-group 1 async mode interactive !
The second thing that looks like it is missing and does not show up in the sho run is the APN setting for the wireless provider.
I'm not sure what the APN setting is for your carrier (I am up in Canada, different providers) but the command is:
cell 0 lte profile create 1 <APN>
For example we use Bell as a service provider and their APN is inet.bell.ca
For things that look unnecessary, the dialer interface is not required at all, the Cell 0 interface handles everything required for network access.
ā04-25-2018 06:33 PM
Hi Ben
can you post all of your config (erase all ip address)
i try to config my 891lte but nothing append
today i call bell to map sim card with the router imei
and i still not have access to internet
here my config
Building configuration...
Current configuration : 3278 bytes
! Last configuration change at 21:24:46 EDT Wed Apr 25 2018
version 15.5
hostname ST-MET_ST03
boot-start-marker
boot-end-marker
enable secret 5 $1$a0KU$KGm3YyeMofkE32tokJtoO1
aaa new-model
aaa authentication login EXEC local
aaa authentication login Liste-Usagers local
aaa authorization exec default local
aaa authorization network default local
aaa authorization network Liste-Groupes local
ip dhcp excluded-address 173.10.3.1 173.10.3.99
ip dhcp pool Station
import all
network 173.10.3.0 255.255.255.0
dns-server 173.10.3.1 8.8.8.8
default-router 173.10.3.1
interface Cellular0
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface Vlan1
ip address 173.10.3.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip nat inside source list NAT interface Cellular0 overload
ip access-list extended NAT
permit ip 173.10.3.0 0.0.0.255 any
permit ip any any
and the return of the profile still not active
thanks for help
ā04-26-2018 06:27 AM
You ran the cell 0 lte profile create 1 <APN> command?
Can you post the output of show cell 0 all?
