bridge-group on serial interface on ISR4000/IOS XE?
jirka.novak
with ISR29xx we were used to using such configuration:
interface serial 0/0/0:0
  encapsulation ppp
  bridge-group 10
  ppp bridge ip
interface bvi 10
  ip address 10.0.0.2 255.255.255.0
With ISR4000 we found that it is not possible to use bridge-group command any more.
I found that for ethernet interfaces it is possible to use EVC feature with 'interface BDI' command. But it works with ethernet interfaces only.
Is there any new syntax how to use old bridge-group on IOS-XE?
Thank you for any advice.
jirka.novak
in meantime I found solution for our case...
What I missed in my original description is that other side of PPP connection is modem/bridge with PPP (patton modem in our case). This modem is capable PPP half-bridge feature.
To interface with such modem we use configuration above on ISR 29xx. In other words, there is the only one interface in bridge group (int serial 0/0/0:0) and it allows ISR to cooperate with PPP half-bridge device.
We found that on ISR4xxx, you don't have to use bridge group to make it running:
interface Serial0/1/0:0
ip address 10.2.0.1 255.255.255.248
encapsulation ppp
ppp bridge ip
Sincerely yours,
Jirka Novak
thanks for sharing it.
