Bridge T1 over Ethernet to Pix?
MagellanTX
I have a 1841 that I want to use to bridge my T1 over to ethernet so I can assign my T1 IP address to the outside interface of my pix.
I have the 1841 with an Internal CSU and a crossover cable going from FA0/0 to the Pix outside. I have disabled ip routing on the 1841 and set both s0/0/0 and fa0/0 to bridge group 1. I have set the bridging protocol to ieee but I cannot ping from the PIX. Is what I'm trying to setup possible?
Thanks!
6 Replies 6
Yes, it's possible. However, for you to test connectivity using pings you need to permit icmp echo reply packets on your outside interface.
If you don't have an ACL applied already on the outside interface then configure the following on the PIX and test.
access-list 101 permit icmp any any echo-reply
access-group 101 in interface outside
HTH,
Sundar
Thank you for the reply. I do have ICMP permitted on the pix I actually had it in use on a cable modem before this T1 went in place. I think the problem I have is in the bridging on the router. I see that I am getting RX packets but no TX packets when I do a 'sho bridge'
Got it.
Traffic local to the outside subnet of the PIX will only be getting bridged. If you want to ping and route IP on the outside router then you need to configure something called IRB (Integrated Routing & Bridging).
Here's a couple of links that can help you with that.
http://www.cisco.com/en/US/products/hw/switches/ps298/products_configuration_example09186a0080093e4f.shtml
http://www.cisco.com/en/US/products/hw/switches/ps5304/products_configuration_guide_chapter09186a00800f0a86.html#xtocid4
HTH,
Sundar
I guess either I am configuring it wrong or misunderstanding bridging. Attached is the config my router has. The IP address that's normally assigned to S0/0/0 I have assigned to the outside of the PIX. (The FA0/1 on the router address is only there for management. My PIX is directly connected to FA0/0. I want the PIX to handle all the routing and the 1841 simply to pass the traffic to the T1. Do I still need IRB for this or can I use simple bridging?
Thanks for all the help!
Building configuration...
Current configuration : 1000 bytes
version 12.3
hostname ATT
boot-start-marker
boot-end-marker
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
no ip routing
no ip cef
no ftp-server write-enable
interface FastEthernet0/0
no ip address
no ip route-cache
speed 100
full-duplex
bridge-group 1
interface FastEthernet0/1
ip address 172.32.1.254 255.255.255.0
no ip route-cache
duplex auto
speed auto
interface Serial0/0/0
bandwidth 1536
no ip address
encapsulation ppp
no ip route-cache
service-module t1 timeslots 1-24
service-module t1 remote-alarm-enable
service-module t1 fdl both
bridge-group 1
ip classless
ip http server
control-plane
bridge 1 priority 1
bridge 1 protocol ieee
line con 0
line aux 0
line vty 0 4
exec-timeout 0 0
login
end
Did you ever get this to work? I am looking to do the same thing...
Hello Sundar,
I don't think it is possible to do bridging in this scenario.
the typical scenario is that ethernet frames are bridged over a FR PVC for example to be delivered at a remote end LAN segment
see
http://www.cisco.com/en/US/docs/ios/11_0/router/configuration/guide/ctb.html#wp2326
But here there is a T1 link and a firewall in a ethernet segment.
T1 encapsulation can be HDLC, PPP, FR but it is doing IP over HDLC or PPP or FR.
I may be wrong but to work the provider router should take part in the bridging over the wan
Hope to help
Giuseppe
