Bridging and NAT with VDSL (VDSL2) on Cisco 867VAE
rolakron1
Hi!
I'm trying to set up my Cisco 867VAE with one bridged ethernet port and three NAT-ports. (FastEthernet0 as bridged, FastEthernet1, 2 and 3 as NATed)  I've set it up so I now get IP-addresses from my ISP's DHCP-server, all ports bridged. My LAN subnet is 172.31.1.0/24
But I haven't found how to set up NAT with VDSL2. I'm quite new with configuring Cisco through terminal (and that's probably one reason why I don't get it working) I've tried experimenting with different configurations, but with no success. I guess I could get it up and running if I decided to use all ports as NAT, but that's not what I want or need.
Can someone help me with this?
Below is my running config:
Building configuration...
Current configuration : 1205 bytes
! Last configuration change at 14:09:13 UTC Wed Feb 8 2023
version 15.2
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
wan mode dsl
no ip routing
no ip cef
no ipv6 cef
controller VDSL 0
 operating mode vdsl2
interface ATM0
 no ip address
 no ip route-cache
 no atm ilmi-keepalive
 bridge-group 1
interface Ethernet0
 no ip address
 no ip route-cache
 bridge-group 1
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
interface Vlan1
 no ip address
 no ip route-cache
 bridge-group 1
ip forward-protocol nd
no ip http server
no ip http secure-server
mac-address-table aging-time 15
bridge 1 protocol ieee
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
 transport input all
scheduler allocate 60000 1000
end
0 Replies 0
