When using PBR, should it be ESSENTIAL or ADVANCED?
Takashi Satoh
Is it possible to weight bgp using route-map even with DNA essential?
I'm currently thinking about deploying 8200L.
In particular, I want to design route weighting using route-map with bgpv4, and I can't decide if the DNA license should be essential or advanced.
The specs state that PBR is available in independent mode, so I'm assuming I can set it up in essential.
I would like to set up something like this
route-map pbr permit 10
set local-preference 150
router bgp 62000
bgp log-neighbor-change
neighbor 192.168.1.0 route-map pbr out
Good Q.
but you can try config by yourself and check.
Hello
Layer2- Layer 3 routing are under the perpetual features inclusive with DNA essentials so PBR should work, however looking at your OP and the route-map pbr,  it isn't doing any Policy-Based Routing as it is only set with a bgp local preference attribute, also I cannot tell if the route-map that it set outbound is towards and IBGP or EBGP peer, but ether way PBR isn't in affect
Kind Regards
Paul
