Bridging same subnets across VPN
laposilaszlo
hello,
Is it possible to bridge the same subnet across a VPN.(i need to connect two audio devices that need to be in the same subnet)
(it doesen't have to be secure.(no ipsec) it can be a gre tunnel))
thank you,
laszlo
Giuseppe Larosa
Hello Laslo,
you can use L2TPv3 if supported on your devices
see
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gtl2tpv3.html
Hope to help
Giuseppe
paolo bevilacqua
No true IP device never requires to be in the same subnet.
If you read the specs for your device, you will find how to configure for routing.
