Bridging
tobymundy57
How often do ports have a default port priority?
Georg Pauwen
the short answer is: you are right on everything.
Thank you
Hello
@tobymundy57 wrote:
Are there 3 equal best paths to the RB, root bridge, out port 2,4 and 8? < no port 2 is the designated port after the root port
Is the best path to the RB, root bridge, is out port 3? < yes
Does each of the ports have a default port priority? < yes they do but  again it depends on the ports speeds for stp to calculate
Is the cost from this switch to the root bridge 19? < here the interface stp cost are the same for all 4 ports
For reference
lowest bridge id
lowest path cost
lowest sending bridge id
lowest sending port id
lowest receiving port id
Kind Regards
Paul
Good stuff
