Brigding accross WAN Slow perfomance
Dear all
I have configure brigding between 256 K Leaase line between my two warehouse.
i.e WH1 & WH2
Previous this two WH connected with Leaser link .
My all servers are in warehouse-1
AFter configuration of briding user giving complain that there server access from wh-1 is very slow.
I have 3 VLAN in wh1
One is server , user & Wireless.
192.168.249.0 VLAN 101 FOR SERVER
192.168.245.0 VLAN1 FOR USER
192.168.255.0 WIRELESS VLAN 500
We are using Aruba Wireless .My main controller in wh1.
some of the APs are in wh3.
AFter configuing bridging My APs are getting IP address from my DHCP .but all aps in wh3 went in air monitor and they r not able to communicate with ARUBA controller ( NOT ABLE TO MAKE GRE TUNNEL BETWEEN CONTROLLER & AP ).
If i disable my lease line & enable my leaser link between WHs .All aps working fine in WH-3.
So HOW TO SOLVE THESE TWO ISSUE.
Slow perfomance & wireless.
My configuration as below .
WH1#
Building configuration...
Current configuration:
version 11.3
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service udp-small-servers
service tcp-small-servers
enable secret xxx
no ip routing
no ip domain-lookup
interface Ethernet0
no ip address
ip route-cache
bridge-group 1
interface Serial0
ip address 10.10.20.1 255.255.255.252
ip route-cache
bridge-group 1
interface BRI0
no ip address
no ip route-cache
shutdown
interface BVI1
ip address 192.168.245.22 255.255.255.0
no ip route-cache
ip classless
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line vty 0 4
password xxx
login
end
WH1#
AND
WH3#sh run
version 12.0
service timestamps log datetime msec localtime show-timezone
hostname WH3-RNA-LL
logging buffered 4096 debugging
ip subnet-zero
no ip routing
no ip domain-lookup
isdn switch-type basic-net3
clock timezone AST 4
bridge irb
interface Ethernet0
description connected Etherenet lan
no ip address
no ip directed-broadcast
ip route-cache
no keepalive
bridge-group 1
interface Serial0
ip address 10.10.20.2 255.255.255.252
ip route-cache
bridge-group 1
interface BRI0
description connected ls_wh
no ip address
encapsulation ppp
no ip route-cache
shutdown
dialer rotary-group 0
no fair-queue
interface Dialer0
ip unnumbered Ethernet0
encapsulation ppp
no ip route-cache
no ip split-horizon
dialer in-band
dialer idle-timeout 180
dialer map snapshot 1 name ls_wh broadcast 043479044
dialer map ip 192.168.245.1 name ls_wh broadcast
dialer hold-queue 10
dialer-group 1
snapshot server 15 dialer
no fair-queue
ppp authentication chap
ppp multilink
interface BVI1
ip address 192.168.245.23 255.255.255.0
no ip route-cache
ip classless
no logging trap
dialer-list 1 protocol ip permit
bridge 1 route ip
WH3-#
6 Replies 6
Pavel Bykov
Level 5
Level 5
Hi. You are talking about WH1 and WH2, but you have configs for WH1 and WH3. Is this correct?
Also, you are running IRB, but have routing disabled. Try enabling routing by issuing "ip routing" command.
The other thing that pops into my mind is MTU, which can come into play. If frames are too big, they will be fragmented, which will require CPU to process every packet. Check fragmentation counters, if they are going up during the communication.
Dear Support
If I am enabling routing I am loosing the connectivity....of router .I am nt able to do telnet.
I have check with ARUBA
I have took packet capture I am getting following message
PAPI_Send failed from 192.168.255.229 to 192.168.255.11 port 8224 PAPI msgtype 0
Hence port UDP 8224 & 8211 is blocking through Bridging ...
Tell me why my briging blocking this ports.
I have no access list on my briding router.
paolo bevilacqua
invariably bridging give this kind of problems.
Sometime it's slowness, something packets are lost ...
Do yourself a favor, convert to regular routing and everything will work nicely.
I HAVe recevied following asnwer from ARUBA
I can see from ping output that you have issue in packets 1500 and more (without DF bit set), actually, you are adding .1q tag so 1500 byte packet = 1518 Ethernet frame.
This might cause issue for large papi packets as they will be dropped in the link between AP and controller. Please work on solving this issue and
hOW TO SOLVE THIS ISSSUE.
I am using cico 1600 with 10 mbps hlf duplex ethernet router.
why have you got a bvi at on each router, when i have done this in the past no ip routing to make one router a bridge and the second router to be the BVI, which is the interfacee between bridging and routing.
I didnt understad wht ur trying to say.....
