BROADCAST NETWORK - OSPF Full Adjacency - Some routes not advertised
Hello to the community.
I have this topology:
The green devices are switches layer 2, the blue devices are switches layer 3.
I use the VLAN250 as transit network, the green devices has only the vlan250 (L2) permitted on every trunk:
SWT-A:
router ospf 1
router-id 192.250.0.254
network 10.100.68.0 0.0.0.255 area 0
network 10.250.0.0 0.0.0.255 area 0
network 192.168.68.0 0.0.0.255 area 0
network 192.168.240.0 0.0.0.255 area 0
SWT-B:
router ospf 1
network 10.100.69.0 0.0.0.255 area 0
network 192.168.69.0 0.0.0.255 area 0
network 192.168.253.0 0.0.0.255 area 0
SWT-C:
router ospf 1
router-id 192.250.0.1
network 10.100.70.0 0.0.0.255 area 0
network 192.168.70.0 0.0.0.255 area 0
network 192.168.74.0 0.0.0.255 area 0
network 192.168.251.0 0.0.0.255 area 0
network 192.168.252.0 0.0.0.255 area 0
SWT-D:
router ospf 1
network 192.168.71.0 0.0.0.255 area 0
network 192.168.254.0 0.0.0.255 area 0
The configuraton of VLAN250 is the same for all devices:
interface Vlan250
ip address 10.250.0.X 255.255.255.0
ip ospf network broadcast
The neighboring:
SWT-A (DR):
192.168.69.253 1 FULL/DROTHER  00:00:31 10.250.0.4 Vlan250
192.168.254.1   1 FULL/DROTHER  00:00:37 10.250.0.7 Vlan250
192.250.0.1       1 FULL/BDR           00:00:30 10.250.0.6 Vlan250
SWT-B:
192.168.254.1 1 2WAY/DROTHER 00:00:37 10.250.0.7 Vlan250
192.250.0.254 1 FULL/DR             00:00:32 10.250.0.1 Vlan250
SWT-C (BDR):
SWT-D:
192.168.69.253 1 2WAY/DROTHER 00:00:31 10.250.0.4 Vlan250
Here the issue, anyone receive the routes of the DR and the 192.168.253.0/24 of SWT-B.
Show ip route ospf:
SWT-A:
O 10.100.69.0/24 [110/2] via 10.250.0.4, 01:17:16, Vlan250
O 10.100.70.0/24 [110/2] via 10.250.0.6, 01:17:16, Vlan250
O 192.168.69.0/24 [110/2] via 10.250.0.4, 01:17:16, Vlan2501
O 192.168.70.0/24 [110/2] via 10.250.0.6, 01:17:16, Vlan250
O 192.168.71.0/24 [110/2] via 10.250.0.7, 01:17:16, Vlan250
O 192.168.74.0/24 [110/2] via 10.250.0.6, 01:17:16, Vlan250
O 192.168.251.0/24 [110/2] via 10.250.0.6, 01:17:16, Vlan250
O 192.168.252.0/24 [110/2] via 10.250.0.6, 01:17:16, Vlan250
O 192.168.254.0/24 [110/2] via 10.250.0.7, 01:17:16, Vlan250
SWT-B:
O 10.100.70.0/24 [110/2] via 10.250.0.6, 01:17:06, Vlan250
O 192.168.70.0/24 [110/2] via 10.250.0.6, 01:17:06, Vlan250
O 192.168.71.0/24 [110/2] via 10.250.0.7, 01:17:06, Vlan250
O 192.168.74.0/24 [110/2] via 10.250.0.6, 01:17:06, Vlan250
O 192.168.251.0/24 [110/2] via 10.250.0.6, 01:17:06, Vlan250
O 192.168.252.0/24 [110/2] via 10.250.0.6, 01:17:06, Vlan250
O 192.168.254.0/24 [110/2] via 10.250.0.7, 01:17:06, Vlan250
SWT-C:
O 10.100.69.0/24 [110/2] via 10.250.0.4, 01:17:06, Vlan250
O 192.168.69.0/24 [110/2] via 10.250.0.4, 01:17:06, Vlan250
SWT-D:
Many thanks and I will be available for other shows.
Gabriele.
12 Replies 12
balaji.bandi
On the Quick look why these 2 router ID Same ?
SWT-A:
router ospf 1
SWT-B:
router ospf 1
BB
I made a mistake in the copy:
SWT-A:
router ospf 1
SWT-B:
router ospf 1
Ok thank you, after modified ( or corrected in the config)
Can you please post new output what you seeing wrong (if the original post output not changed ?)
BB
The issue is related to the routing tables:
SWT-A:
SWT-B:
SWT-C:
SWT-D:
Anyone receive from SWT-A:
10.100.68.0/24
192.168.68.0/24
192.168.240.0/24
and from SWT-B:
192.168.253.0/24
It is strange because the other neighbors receive from SWT-B the 10.100.69.0/24 and the 192.168.69.0/24, not the 192.168.253.0/24.
The issue is related to the routing table,
no one receive the networks from SWT-A and the network of SWT-B 192.168.253.0/24.
I also notice that, even the network is in routing table, I'm not able to reach the 192.168.254.100 (host on SWT-D).
I'm able to reach the address 192.168.254.1 (IP of a VLAN of SWT-D) but not his host.
It is instead reachable from the LAN.
Jaderson Pessoa
SWT-B:
router ospf 1
network 192.168.253.0 0.0.0.255 area 0   < this network has a interface up/up on this router?
Could you provide output from:
show ip ospf interface
show ip ospf database network
Jaderson Pessoa
*** Rate All Helpful Responses ***
yes the interface is UP/UP:
Vlan20 192.168.69.253 YES manual up up
SWT-A:
Vlan250 is up, line protocol is up
Internet Address 10.250.0.1/24, Area 0, Attached via Network Statement
Process ID 1, Router ID 192.250.0.254, Network Type BROADCAST, Cost: 1
Topology-MTID Cost Disabled Shutdown Topology Name
0 1 no no Base
Transmit Delay is 1 sec, State DR, Priority 1
Designated Router (ID) 192.250.0.254, Interface address 10.250.0.1
Backup Designated router (ID) 192.250.0.1, Interface address 10.250.0.6
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
oob-resync timeout 40
Hello due in 00:00:07
Supports Link-local Signaling (LLS)
Cisco NSF helper support enabled
IETF NSF helper support enabled
Index 2/2, flood queue length 0
Next 0x0(0)/0x0(0)
Last flood scan length is 1, maximum is 4
Last flood scan time is 0 msec, maximum is 10 msec
Neighbor Count is 3, Adjacent neighbor count is 3
Adjacent with neighbor 192.168.69.253
Adjacent with neighbor 192.168.254.1
Adjacent with neighbor 192.250.0.1 (Backup Designated Router)
Suppress hello for 0 neighbor(s)
SWT-B:
Internet Address 10.250.0.4/24, Area 0, Attached via Network Statement
Process ID 1, Router ID 192.168.69.253, Network Type BROADCAST, Cost: 1
0 1 no no Base
Transmit Delay is 1 sec, State DROTHER, Priority 1
Hello due in 00:00:03
Can be protected by per-prefix Loop-Free FastReroute
Can be used for per-prefix Loop-Free FastReroute repair paths
Next 0x0(0)/0x0(0)
Last flood scan length is 0, maximum is 3
Last flood scan time is 0 msec, maximum is 4 msec
Neighbor Count is 3, Adjacent neighbor count is 2
Adjacent with neighbor 192.250.0.254 (Designated Router)
SWT-C:
Internet Address 10.250.0.6/24, Area 0, Attached via Network Statement
Process ID 1, Router ID 192.250.0.1, Network Type BROADCAST, Cost: 1
0 1 no no Base
Transmit Delay is 1 sec, State BDR, Priority 1
Hello due in 00:00:01
Next 0x0(0)/0x0(0)
Last flood scan length is 0, maximum is 2
SWT-D:
Internet Address 10.250.0.7/24, Area 0, Attached via Network Statement
Process ID 1, Router ID 192.168.254.1, Network Type BROADCAST, Cost: 1
0 1 no no Base
Hello due in 00:00:05
Next 0x0(0)/0x0(0)
Last flood scan length is 1, maximum is 1
SWT-A:
OSPF Router with ID (192.250.0.254) (Process ID 1)
Net Link States (Area 0)
Routing Bit Set on this LSA in topology Base with MTID 0
LS age: 285
Options: (No TOS-capability, DC)
LS Type: Network Links
Link State ID: 10.250.0.1 (address of Designated Router)
Advertising Router: 192.250.0.254
LS Seq Number: 80000005
Checksum: 0x419E
Length: 40
Network Mask: /24
Attached Router: 192.250.0.254
Attached Router: 192.168.69.253
Attached Router: 192.168.254.1
Attached Router: 192.250.0.1
SWT-B:
OSPF Router with ID (192.168.69.253) (Process ID 1)
LS age: 286
Checksum: 0x419E
Length: 40
Network Mask: /24
SWT-C:
OSPF Router with ID (192.250.0.1) (Process ID 1)
LS age: 286
Checksum: 0x419E
Length: 40
Network Mask: /24
SWT-D:
OSPF Router with ID (192.168.254.1) (Process ID 1)
LS age: 286
Checksum: 0x419E
Length: 40
Network Mask: /24
Thanks and regards.
Yes, the interface is UP/UP.
SWT-A:
0 1 no no Base
Next 0x0(0)/0x0(0)
LS age: 285
Checksum: 0x419E
Length: 40
Network Mask: /24
SWT-B:
0 1 no no Base
Next 0x0(0)/0x0(0)
LS age: 286
Checksum: 0x419E
Length: 40
Network Mask: /24
SWT-C:
0 1 no no Base
Next 0x0(0)/0x0(0)
LS age: 286
Checksum: 0x419E
Length: 40
Network Mask: /24
SWT-D:
0 1 no no Base
Next 0x0(0)/0x0(0)
LS age: 286
Checksum: 0x419E
Length: 40
Network Mask: /24
SWT-A:
0 1 no no Base
Next 0x0(0)/0x0(0)
LS age: 285
Checksum: 0x419E
Length: 40
Network Mask: /24
SWT-B:
0 1 no no Base
Next 0x0(0)/0x0(0)
LS age: 286
Checksum: 0x419E
Length: 40
Network Mask: /24
SWT-C:
0 1 no no Base
Next 0x0(0)/0x0(0)
LS age: 286
Checksum: 0x419E
Length: 40
Network Mask: /24
SWT-D:
0 1 no no Base
Next 0x0(0)/0x0(0)
LS age: 286
Checksum: 0x419E
Length: 40
Network Mask: /24
SWT-A:
0 1 no no Base
Next 0x0(0)/0x0(0)
LS age: 285
Checksum: 0x419E
Length: 40
Network Mask: /24
SWT-B:
0 1 no no Base
Next 0x0(0)/0x0(0)
LS age: 286
Checksum: 0x419E
Length: 40
Network Mask: /24
SWT-B:
0 1 no no Base
Next 0x0(0)/0x0(0)
i cant see your network advertise on this router, could you provide the show running-config and show ip ospf interface
Jaderson Pessoa
SWT-C:
0 1 no no Base
Next 0x0(0)/0x0(0)
LS age: 286
Checksum: 0x419E
Length: 40
Network Mask: /24
SWT-D:
0 1 no no Base
Next 0x0(0)/0x0(0)
LS age: 286
Checksum: 0x419E
Length: 40
Network Mask: /24
