bryan p
bryanperrine78
please help!!!
Im using a cisco 1841 router with one vlan1 on it to access internet and it work..recently i wanted to create a second vlan 2 i have done all the configuration nat,access-list i can ping vlan2 from the pcs but this vlan2 cant access internet ..what config should i do?thank you
2 Accepted Solutions
You duplicated to much of the config as both VLANs will use the same NAT and dialer-interface to communicate to the internet.
First remove the unneeded config:
no ip nat inside source list 2 interface dialer2 overload
no dialer-list 2 protocol ip permit
no access-list 2 permit 192.168.x.x 0.0.0.255
The only thing you need in addition to your new vlan is the config that the new VLAN should also do NAT:
access-list 1 permit 192.168.x.x 0.0.0.255
no, the new line will be added to the list and both networks will get NATed.
7 Replies 7
Are the PCs using the vlan2-ip as the default-gateway?
If yes, there is probably something wrong with your ACL or NAT-config. Please post your config (with removed passwords).
yeah vlan2 will be use as gateway..here is the config
interface fastethernet0
 switchport access vlan2
 no ip address
interface fastethernet1
 no ip address
 interface fastethernet2
 no ip address
interface fastethernet3
no ip address
interface fastethernet4
 description wan interface to
 no ip address
 load-interval 30
 duplex full
 speed 100
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface vlan1
 description to custumer lan
 ip address 10.1.x.x 255.255.0.0
 ip nat inside
 ip virtual-reassembly in
interface vlan2
 ip address 192.168.x.x 255.255.255.0
 ip nat inside
interface dialer 1
 description pppoe session customer 6/2 mb
 ip ddns update hostname xxxxxxxxxxxx
 ip ddns update noip
 ip address negociated
 ip mtu 1452
 ip nat outside
 encapsulation ppp
 ip top adjust-mss 1452
 load-interval 30
 dialer pool 1
 dialer-group 1
 ppp chap hostname xxxxxxxx
 ppp chap password xxxxxxxx
ip forward-protocol nd
no ip http server
no ip fttp secure-server
ip nat inside source list 1 interface dialer1 overload
ip route 0.0.0.0 0.0.0.0 dialer1
dialer-list 1 protocol ip permit
snmp-server community
access-list 1 permit 10.1.x.x 0.0.255.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role non
mgcpbehavior comedia-check-media-src disable
mgcp behavior comedia-sdp-fore disable
mgcp profile default
thank you..but will the command 'access-list 1 permit 192.168.x.x 0.0.0.255' will make vlan1 stop working?
thanks a lot karsten it works :) cheers
One more thing. For PPPoE, the MTU is typically 1492 unless told from the ISP to use something different:
interface dialer 1
 ip mtu 1492
