How do I configure Static IP and Default Gateway on a WAN port on a Cisco Router 2800
gepistola
I was able to configure the IP Address but how about the Default GatewaY?
I did
ip address 200.2.14.2 subnet 255.255.255.248
What's the command for default gateway let's say the gateway is 200.2.14.1?
Leo Laohoo
You don't need to.
really but why cant i ping public IPs outside my LAN.. altho i can just ping the gateway 200.2.14.1?
how can i access WAN side?
Hi gepistola,
where are you ping from? router or LAN?
if you ping from LAN, you need NAT to reach public IPs
croessler1
If the default-gateway should be 200.2.14.1 then set a static route ip route 0.0.0.0 0.0.0.0 200.2.14.1
