buffer information
shivlu jain
Level 5
Level 5
can anyone tell me whats the given packet means. I got the logs after debug sanity command.
Buffer information for Small buffer at 0xD809340
data_area 0x789AD184, refcount 0, next 0xD13D8B8, flags 0x0
linktype 0 (None), enctype 0 (None), encsize 14, rxtype 1
if_input 0x0 (None), if_output 0x0 (None)
inputtime 1d09h (elapsed 00:00:00.320)
outputtime 1d09h (elapsed 00:00:18.580), oqnumber 65535
datagramstart 0x789AD1CA, datagramsize 62, maximum size 260
mac_start 0x789AD1CA, addr_start 0x789AD1CA, info_start 0x0
network_start 0x789AD1D8, transport_start 0x789AD1EC, caller_pc 0x29596C
regards
shivlu
Giuseppe Larosa
Hello Shivlu,
I didn't find a reference for debug sanity in the command lookup tool.
However, my guess is the following:
this output is related to a small buffer system buffer.
the packet is simply holded there for some time :
the packet is 62 byte in size.
no info about the physical interface is available :
and the packet is without a L2 encapsulation :enctype 0 (None)
the packet was probably held for 18 msec before being sent to the cpu for process switching.
be aware that the "packet" could also be the first 62 bytes of a longer packet sent to to the system buffers before it needed to be process switched.
This is platform dependent.
Hope to help
Giuseppe
