bug CSCuf17023 and CSCtt45381
veerever
To resolve bug CSCuf17023 and CSCtt45381 I need to update cisco router 2901 , IOS c2900-universalk9-mz.SPA.151-4.M3.
Can anyone please tell me he download and update procedure
InayathUlla Sharieff
Veer,
To download the software you need to have valid CCO id  and software contract associated to this router.
Link to download the software is:
https://software.cisco.com/download/release.html?mdfid=282774223&flowid=7438&softwareid=280805680&release=15.1.4M&rellifecycle=ED&relind=AVAILABLE&reltype=all
Upgrade procedure:
Easy way to upgrade the firmware:
1- Download the firmware.
2- Copy the firmware to the router flash.
3- Modify the boot system variable config on the switch to the latest ios.
4- save the config.
5- reload.
Some links:
http://www.thegeekstuff.com/2011/06/upgrade-cisco-ios-image/
http://www.cisco.com/c/en/us/td/docs/routers/access/1900/software/configuration/guide/Software_Configuration/upgrade.html
Inayath
*Plz dont forget to rate the posts which are usefull.
