Showing results forĀ
Search instead forĀ
Did you mean:Ā
yeow_km
Beginner
installing a 2nd PSU to a C3925 router
Currently my C3925 router is running on a single power supply.
we intend to get a 2nd PSU for redundany.
question, do I have to shutdown the router in order to install the 2nd PSU, or is it hot plug ?
there are video online showing how to add a 2nd PSU for C3845 router but not C3925.
how different are the installation?
i presume to be minimum since both are of the same range.
1 REPLY 1
InayathUlla Sharieff
Yes its hot-swappable.
http://www.cisco.com/c/en/us/td/docs/routers/access/2900/hardware/installation/guide/Hardware_Installation_Guide/Internal_Modules.html#pgfId-1182874
