burst calculation in CAR on ATM subinterface
pacquaviva
I would like to calculate a better burst value to implement with rate limit command on ATM subinterface.
We have a PCR equal to 10Mbps and I tought that the normal burst can be 10% of PCR/8 (125000 bytes) and the same for exceed burst.
Is it correct?
Thank you.
Regards.
Paolo
sean
Level 3
Level 3
I think it should be (PCR * 1.5)/8
Hope this helps.
