burst config
leungcm
we would like to implement the burst setting on Fast ethernet. e.g.
normal: 10M
burst: 3M
do we use the "rate limited" to do it? please advise
Best regards
royalblues
Level 10
Level 10
you need to either use QoS policing or CAR to configure the same
eg..
access-list 10 permit any
class-map match-all rate-limit
match ip address 10
Policy-map rate-limit
class rate-limit
police 10000 30000 confirm-action-transmit exceed-action-drop
int fa 0/1
service-policy output rate-limit
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225see/scg/swqos.htm#wp1044737
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt1/qcfcar.htm
HTH, rate if it does
Narayan
