BVI and rate limit
sdg2009sdg
I have a Cisco 831 set up to do bridging
eth0 no ip,
eth1 no ip,
bvi1 has the ip
The problem is I've lost the ability to rate limit, you cannot rate limit on the bvi interface and when I apply my rate limit command to eth0 or 1 it no longer works…any Ideas…
--Scott
owillins
Level 6
Level 6
To configure committed access rate (CAR) and distributed committed access rate (DCAR) policies, use the rate-limit command in interface configuration mode. To remove the rate limit from the configuration, use the no form of this command.
rate-limit {input | output} {bps | access-group acl-index | [rate-limit] rate-limit-acl-index] | dscp dscp-value | qos-group qos-group-number} burst-normal burst-max conform-action conform-action exceed-action exceed-action
no rate-limit {input | output} {bps | access-group acl-index | [rate-limit] rate-limit-acl-index] | dscp dscp-value | qos-group qos-group-number} burst-normal burst-max conform-action conform-action exceed-action exceed-action
Troubleshooting Direction: There are different types of rate-limit:
access-list rate-limit
clear ip rsvp signalling rate-limit
debug ip rsvp rate-limit
ip icmp rate-limit unreachable
ip multicast rate-limit
ip pim register-rate-limit
ip rsvp atm-peak-rate-limit
logging rate-limit
rate-limit
show access-lists rate-limit
show interfaces rate-limit
show ip ospf timers rate-limit
show ip rsvp atm-peak-rate-limit
show ip rsvp signalling rate-limit
