Showing results forĀ
Search instead forĀ
Did you mean:Ā
C1000 Catalyst sofware issue
projectsEDS
Hi, I have recently flashed the C1000-16T-2G-IN switch, since then the top toolbar used for save/ logout and some tool tips got misaligned. Can't able to access those, Please advise to over
@projectsEDS
 If you have SSH access to the switch, try to restart the HTTP service
 no ip http server
ip http server
If you dont, maybe you should upgrade it or downgrade it
balaji.bandi
This looks for me Bug or try different browsers- by the way what is the IOS Code running on the device ?
BB
