ospf multizone understanding
Hello support,
I have a question regarding ospf with multiple areas, it's possible to have a area dehind another area outside zone 0?
Attached is the diagram, can we have area 10 ?
6 Accepted Solutions
Yes You need it since area 10 can not direct connect to backbone area 0
MHM
Robert Plunkett
Remember, when creating your virtual link you should use you ospf router ID.
Hello
based on your topology-why not have that rtr in the same area so no need for a VL?
Kind Regards
Paul
Joseph W. Doherty
Is it possible, yes.  Will it work correctly, not without some additional configuration.
Others have explained using virtual link or not having the separate remote area
Other possible options would be to use tunnels and/or a separate VLAN, to either extend the remote area to an ABR, or extend area zero to that area.
Possibly overkill, but I would consider insuring each area has a physical attachment to area zero.
If you do that, you have two choices, which are, extend site's area up to HQ ABR, or make site WAN router an ABR.  There are pluses and minuses to both approaches, also impacted by advanced Cisco OSPF configuration options.
12 Replies 12
Okay, that means if you use this scenario, you must therefore use the virtual link?
MHM
Okay, many thanks, will read the document sent.
Last thing please, how can i know the number of routers in an area?
Robert Plunkett
Torbjørn
@MHM Cisco World is correct that a virtual link can be used to achieve this. I just want to add that you should avoid this situation if possible. If you do find yourself in a situation where you have to use a virtual link, you should only rely on this as a temporary fix.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Hello
Kind Regards
Paul
Hi Paul driver
you proposition is correct. In my case, i have manys sites connected one after one by WAN links (each site is a different city).
So, to separate things, i think it's better to put each site on a separate area.
Joseph W. Doherty
imhessam
All non-backbone area's in OSPF need to be connected to the backbone area (database exchange). as others explained you can use virtual link considering it's a temporary solotion (DNA flag on LSA, dependency on transit area, ......)
