C1101 IP address command not present
ccollins
I have a brand new C1101 that came with 16.12.4. The command "ip address" is not an option:
>en
Password:
newswitch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
newswitch(config)#int gi0/1/0
newswitch(config-if)#switchport host
switchport mode will be set to access
spanning-tree portfast will be enabled
channel group will be disabled
newswitch(config-if)#ip add?
% Unrecognized command
Can someone provide direction or documentation? The Documentation I have read so far indicates the command should exist.
15 Replies 15
Some time code may be bug, there may be Future use, we know the facts now.
if this is still an issue, raising TAC case help you help support cisco also.
BB
