C1111-4P and OSPF
Abd Mhd
Hi community,
Can any one tell is OSPF Supported in C1111-4P router?
I want to use C1111-4P  as branch router connected to HQ
as you Know (SL-1100-4P-IPB) is Default IP Base License
your help is highly appreciated
BR,
pman
Yes, C1111-4P supports OSPF with its default license (IP base)
Table 17.          Cisco 1000 Series licenses
Part number
Bundles
Features
SL-1100-8P-IPB
SL-1100-4P-IPB
SL-1100-2P-IPB
IP Base (default)
Routing protocols, ACL, NAT, QoS, BFD, VRF Lite, IP SLA Responder.
https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/datasheet-c78-739512.html#CiscoIOSSoftwarelicensingandpackaging
the short answer is: the IP Base License supports routing protocols including OSPF.
