ENCS ASAv Ping delay
Hi, I have ENCS5408, and I'm trying to figure out 'ping delay issue' on ASAv
Here's Firmware / Version info
Device : ENCS5408
Hardware version : 2 / CPLD Version : 2.0
BIOS version : ENCS54_3.00 (Build date : 12/14/2020)
CIMC Firmware : 3.2(13.2)
NFVIS Firmware : 4.2.1-FC3
ASAv : asav9-14-2-15.qcow2
First, I deployed ASAv 9.14.2 and I found ping delay exist in internal area.
so, I delete 9.14.2 and deploy 9.12.3 therefore ping delay was disappear.
Question is, is there something wrong with ASAv 9.14.2 or uncompatible with ENCS5408 ?
P.S. I attached ping test image and I configured only default things
1.128 = ASAv 9.12.3, 1.129 = ASAv 9.14.2.
as far as I recall, 9.14.2 is an interim release. I happened to come across an issue with SNMP in 9.14.x (see the link below). The recommendation is to stick with a Feature or Maintenance release if you run into any issues with an interim release...
"Cisco ASA Interim Release Notes
The software images listed below are Interim releases. They contain bug fixes which address specific issues found since the last Feature or Maintenance release. The images are fully supported by Cisco TAC and will remain on the download site only until the next Maintenance release is available. If you do not have a specific problem which is resolved by an Interim release, we recommend that you use the Feature or Maintenance release images."
https://edledge.com/snmp-issue-with-cisco-asa-ios-9-14-x/
