09-08-2021 08:13 AM
Hi All,
I am trying to enter the following commands in C1111-4P routers and getting an error
ip multicast-routing
ip inspect name sdm_ins_in_100 icmp
ip inspect name sdm_ins_in_100 netbios-ssn
ip inspect name sdm_ins_in_100 netbios-dgm
ip inspect name sdm_ins_in_100 tcp
I took this from a working Cisco 881 Router can anyone say what am i missing on this
VJ
09-08-2021 08:18 AM
Hello @sv_cbe ,
the ip inspect commands are part of security features that may be missing or that need to be enabled.
Likely Zone Based Firewall
you need
ip multicast routing
ip pim sparse-dense mode under interfaces that should process multicast traffic
ip pim rp <address>
Ip address of the RP in small networks an RP can serve all groups.
Hope to help
Giuseppe
09-08-2021 08:45 AM
Thank You Giuseppe for your reply.
Unfortunately i am unable to understand your solution.
I am an Instrumentation guy trying to configure this router (C1111-4P), my requirement is to transmit some process values (Such as Pressure, Temperature, some digital points) configured as OPC points to an external system.
I have written some rules under ACL for allowing/denying.
This "PIM", Ip address of the RP in small networks an RP can serve all groups. I can't get this
VJ
