09-08-2021 05:22 AM
HI guys,
im trying to implement cisco no-advertise community from a router with a local loopback ip 10.1.1.1. im using below syntax on local router and its not working. but its working when i configure it on the neighbor peer with route-map A in syntax. is this a case of ACL/route map works after/before processing etc that is causing the issue?
neighbor 6.6.6.6 route-map A out
neighbor 6.6.6.6 send-community both
access-list 101 permit ip host 10.1.1.1 any
route-map A permit 10
match ip address 101
set community no-advertise
Solved! Go to Solution.
09-08-2021 06:41 AM - edited 09-08-2021 06:42 AM
Hello @ahmedsid432135621 ,
extended IP ACLs are supported in BGP but in an unusual way so it is better to use prefix-lists.
there is no effect on the local node / originating router
the BGP NO_ADVERTISE community allows a node to advertise a prefix or set of prefixes to a peer that can use them ( install them in local IP routing table) but the peer cannot advertise them to other devices.
Otherwise you could simply filter the unwanted prefixes from the peer session using a route-map with a deny section as showed by @balaji.bandi in his post.
Hope to help
Giuseppe
09-08-2021 05:34 AM
Ra-Rb-Rc
Ra will config the route-map with no-advertise,
the effect will be in Rb which will not advertise the prefix.
09-08-2021 05:37 AM - edited 09-08-2021 05:40 AM
there is something strange in your test configuration.
The BGP community no-advertise is a well known community that can be used to make a prefix not advertisable to a third party peer.
You are using an extended ACL that looks like to be thought for user traffic rather then to define a prefix:
You should use a prefix-list to define what prefix(es) should have the BGP community no-advertise when sending to BGP peer 6.6.6.6.
The effect is not on the local node but on the peer 6.6.6.6 that receives the prefix(es) can use it/them, but it cannot advertise it/them to anyone.
Simllarly NO_EXPORT allows to advertise to other iBGP peers but not to eBGP peers.
So regardless of your strange ACL the effects of BGP community no-advertise are seen on the peer in your case on 6.6.6.6 node.
Hope to help
Giuseppe
09-08-2021 05:37 AM
Try below and let us know how it goes.
access-list 101 permit host 10.1.1.1
route-map BB_NO deny 10
route-map BB_NO permit 20
09-08-2021 05:48 AM
Hello @balaji.bandi ,
access-list 101 is an extended ACL
As I have written in my post this kind of filter is not the correct on in this scenario as it is not clear what prefixes would match .
May be only 10.1.1./32
I would use a prefix-list instead,
Setting BGP community NO_ADVERTISE on prefixes that are DENIED to a neighbor is useless it is just enough to deny them = filtered
My understanding is that the original poster has not clear the use and concept of NO_ADVERTISE BGP community expecting it to happen on the local node.
Hope to help
Giuseppe
09-08-2021 06:07 AM
you bring up a good point, since now i remember that extended ACL work differently on BGP than they do on any other application. secondly, are you stating that the no-advertise community has no affect if it is applied on the originating router even if i do use a prefix list? or it pointless to use it on the originating router?
Hope to help
Giuseppe
09-08-2021 07:40 AM
BTW, don't know if this still applies, but years ago, I "stubbed my toe" on no-advertise not working because BGP wasn't configured to use communities (the default, at least then). When configured to do so, then no-advertise worked correctly.
