C1111-8P booting into ROM
Linxuwiz12
I am new to this Cisco Router. I bought this router with the below specs when I turn on the router it is going straight into "ROMMON" Mode how do load the new firmware. Your help will be greatly appreciated.
General InformationManufacturer: Cisco Systems, IncManufacturer
Part Number: C1111-8PManufacturer
Website Address:
http: //www. cisco.
comBrand Name: CiscoProduct
Series: 1100Product
Model: C1111-8PProduct
Integrated Services RouterMarketing Information
Product Type: RouterInterfaces/PortsTotal Number of
Ports: 10Management
Port: YesNumber of
Network (RJ-45) Ports: 8Number of
WAN Ports: 2I/O ExpansionsNumber of Total
Expansion Slots: 1Expansion
Slot Type: SFP
Network & CommunicationEthernet Technology: Gigabit
EthernetNetwork Technology: 10/100/1000Base-TXPower DescriptionPoE (RJ-45)
8 Replies 8
Leo Laohoo
While in ROMMON, post the complete output to the following commands:
1.  dir flash:
2.  set
I typed in boot on rommon it loaded package.conf file after a few minutes it gave the router prompt. I typed in reload
gave the following output
WARNING:
Boot variable either does not exist or buffer is too small
This may impact autoboot of the router. Proceed with caution
Do you wish to proceed with reload anyway[confirm]n
Router#reload
BOOT variable =
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Configuration register is 0x2122
Standby not ready to show bootvar
my apologies Leo I unable to type that command since it is now at the Router prompt.
To fix this, do this:
conf t
 config-registry 0x2102
end
wr
I still getting following message after applying the 0x2102 and reverted back to 0x2122
Router#reload
WARNING:
Proceed with reload? [confirm]
Force the router to boot into ROMMON.
When in ROMMON, enter the ROMMON command:  confreg 0x2102
It no longer goes into ROMMON mode not sure what I did it automatically loads IOS mode with Router prompt showing. If I may go back to original question how do I upgrade to the latest firmware and which one should I download from Cisco website when I did "Show ver" below is the output.
Cisco IOS XE Software, Version 17.03.06
Cisco IOS Software [Amsterdam], ISR Software (ARMV8EL_LINUX_IOSD-UNIVERSALK9-M), Version 17.3.6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2022 by Cisco Systems, Inc.
Compiled Fri 16-Sep-22 01:28 by mcpre
