03-11-2025 09:23 PM
Can I use a LAN ports on a Cisco 1117-4P for a wired Failover connection? I'm the MSP in the diagram. Thanks.
Solved! Go to Solution.
03-12-2025 02:11 AM
I do not see any issue as long as you are able to manage routing and which traffic to use that route. (you need to find out failover scenarios using EEM script / IP SLA..etc)
03-12-2025 02:11 AM
