C1941w and Cisco CP Express Firewall Feature Set
raulzulueta
I have a cisco 1941w with ios c1900-universalk9-mz.SPA.150-1.M2.bin and I am using Cisco CP Express GUI. It tells me that the firewall feature set in unavailable. The IOS image in your router does not support the requested feature.
How do I get CP Express to configure the firewall feature?
12 Accepted Solutions
vragotha
Level 3
Level 3
You need to have the Security license for the firewall features. You can check what license you have with a show version/show license
http://www.cisco.com/en/US/partner/prod/collateral/modules/ps10598/ordering_guide_c07_557736_ps10538_Products_Data_Sheet.html
Jerry Ye
In the command prompt (via console, telnet or ssh) do show license all and post the output here.
jerry
Like I mentioned earlier, you need a Security license. You currently have only a IP Base license
Is that something I need to purchase or is it a download feature set license?
You need to purchase the license from a Cisco reseller. The link below
lists the different license options and the part numbers.
http://www.cisco.com/en/US/prod/collateral/modules/ps10598/ordering_guide_c07_557736_ps10538_Products_Data_Sheet.html
Contact Cisco Licensing (licensing@cisco.com) and they will send you the license file to install on the device
Please post your switch configuration also. The router configuration looks okay.
jerry
The switch is an HP Procurve switch. Do you still want the switch config?
Not really. So in the switch, make sure the trunk port is configure to 802.1q and allow all VLAN's to go through. That is about it.
If it is a Cisco switch the configuration looks like the follow
interface x/x
switchport mode trunk
HTH,
jerry
I wish it was a Cisco switch. HP does things different what they call a trunk is actually an ether-channel of ports.
Your ip nat outside is on the wrong interface. It should be on G0/1, not G0/0.
interface g0/0
no ip nat outside
interface g0/1
no ip nat inside
ip nat outside
HTH,
jerry
Yup. That was I.
Thanks.
17 Replies 17
vragotha
Level 3
Level 3
Jerry Ye
jerry
Here are the outputs of "show ver" "show license" and "show license all"
So I will order the SL-19-SEC-K9 Security License which looks like a paper license. How do I install it on
the router? And does this part number give mu all the feature sets to have firewall and vpn features?
I attached the configuration for my 1941w router. I am unable to ping 10.6.10.250 or 10.6.20.250 which is the switch interface. I can however ping 10.6.1.250 also on the switch interface. What am I missing?
jerry
interface x/x
HTH,
jerry
i cannot ping 8.8.8.8 from any of the sub-interface addresses:
g0/0.10 ip address 10.6.10.250
g0/0.20 ip address 10.6.20.250
all the others
Am I missing a route?
