C1941w and Cisco CP Express Firewall Feature Set
raulzulueta
I have a cisco 1941w with ios c1900-universalk9-mz.SPA.150-1.M2.bin and I am using Cisco CP Express GUI. It tells me that the firewall feature set in unavailable. The IOS image in your router does not support the requested feature.
How do I get CP Express to configure the firewall feature?
17 Replies 17
Your ip nat outside is on the wrong interface. It should be on G0/1, not G0/0.
interface g0/0
no ip nat outside
interface g0/1
no ip nat inside
ip nat outside
HTH,
jerry
Yup. That was I.
Thanks.
So I purchasesd the Security license and installed it on the C1941W router. I can now create VPN tunnels. I am trying to use Cisco CPE to configure the firewall. I am getting very erratic behavior. Sometimes the application comes up and most of the time it does not. It also sometimes says I cannot configure the firewall for several reasons. Is there a firewall feature in this router or not. BTW, I am using g0/0 for the WAN and g0/1.10 , g0/1.11 , g0/1.12 for subinterfaces on the LAN. Is that a problem. I am new to this router and its functionality so please be patient with my questions. We can do a webex if that would help more.
Thank you.
