C2801 router cant read more than 3 WICs?
jammcrae
I was attempting to use my C2801 as the hub in a frame relay setup. However I am only able to go up/up on 2 of the 3 devices needed for this topology. Is this a software limitation? Or am I over looking something here?
R2Cisco_2801#sh inventory
NAME: "chassis", DESCR: "2801 chassis"
PID: CISCO2801 , VID: V02 , SN: FTX1014W1GU
NAME: "WIC/VIC/HWIC 1", DESCR: "WAN Interface Card - Serial (1T)"
PID: WIC-1T= , VID: 1.0, SN: 24609901
NAME: "WIC/VIC 2", DESCR: "WAN Interface Card - Serial (1T)"
PID: WIC-1T= , VID: 1.0, SN: 24942032
NAME: "WIC/VIC/HWIC 3", DESCR: "WAN Interface Card - Serial (1T)"
PID: WIC-1T= , VID: 1.0, SN: 24081265
R2Cisco_2801#sh int des | b Se0
Se0/1/0 up up
Se0/2/0 down down
Se0/3/0 up up Link to C2516 via serial 0
Cisco IOS Software, 2801 Software (C2801-ENTBASEK9-M), Version 12.4(22)YB2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 26-May-09 22:07 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T5, RELEASE SOFTWARE (fc1)
R2Cisco_2801 uptime is 2 hours, 10 minutes
System image file is "flash:c2801-entbasek9-mz.124-22.YB2.bin"
Cisco 2801 (revision 6.0) with 117760K/13312K bytes of memory.
Processor board ID FTX1014W1GU
2 FastEthernet interfaces
3 Serial(sync/async) interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
5 Replies 5
This is an older 1st generation 2801 I assume ? I remember that you can test the interfaces by putting them in 'loopback local' mode. If the interface is okay, it should come up. Can you give that a try ? What cabling do you have connected to that interface ?
I know all WIC modules work on this router because I have switched serial cables between interfaces, however I am unable to get all 3 to work simultaneously
Serial0/1/0 unassigned YES NVRAM down down
Serial0/2/0 unassigned YES unset up up
Serial0/3/0 176.3.47.6 YES NVRAM up up
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater
Device ID Local Intrfce Holdtme Capability Platform Port ID
Cisco_2610XM.ccnplab.statenisland.newyork.nys.ddns
Ser 0/2/0 144 R S I 2610XM Ser 0/0
R5Cisco_1841 Ser 0/3/0 178 R S I 1841 Ser 0/1/0
after switching cable
R2Cisco_2801#
*Oct 22 21:42:02.531: %LINK-3-UPDOWN: Interface Serial0/2/0, changed state to down
*Oct 22 21:42:03.531: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0, changed state to down
*Oct 22 21:42:35.523: %LINK-3-UPDOWN: Interface Serial0/1/0, changed state to up
*Oct 22 21:42:36.523: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0, changed state to up..
it might have something to do with the controller settings. Try and type 'controller' in global config mode and see what options there are.
Can you post the output of 'show diag' ?
hi,
the 3 WICs were detected by the show inventory output.
is DCE/DTE terminations correct?
do you have clock rate configured on the DCE interface?
