C2950 memory error
slicerpro
Hi, I am having high memory usage alerts from my Nagios. It says my C2950 running Version 12.1(22)EA14 is using memory at 80%. I have gone through a few command outputs but don't see any pointers. I will greatly appreciate a second set of eyes on this. Here are some command outputs:
Mark Malone
The only way to clear memory issue is to reboot it , if its still spiking so high after a reboot you should upgrade the IOS as its probably a memory leak in software
INFO: The top 3 processes that are holding less than 1 MB of memory are: 'Pool Manager' is holding 94988 bytes 'SSH Process' is holding 81628 bytes 'SSH Process' is holding 79536 bytes
EDIT: I see your on the last image released for that model
Thanks for the response, while arranging for the change window, something else is picking my curiousity: what is that number that shows under "allocated" column? It is waaay bigger than the total memory itself for processes like 'dead' , 'pool manager' etc.
And oh, the 'init' process is actually holding > 1/2 of the memory. what does this process do?
Philip D'Ath
Cisco 2950's are pretty old ...
What is the normal "baseline" memory usage for your device?  If it has been slowly trending up then it is almost certainly a memory leak, and has already been said, a reboot wil be needed to fix it.
