C2960 bootup
RobCain62830
i will try to give just the basic info. I have a c2960 switch, files were deleted from it. I copied (c2960c405ex-universalk9-mz.152-2.E9.bin) from another switch to a usb. I can get the switch to boot normal from the usb and have copied it to flash but I can not get it to load from flash on "reload" command.
balaji.bandi
After reloading what  Mode ( can you post the Complete boot logs)
boot usbflash0:c2960c405ex-universalk9-mz.152-2.E9.bin
Once it booted
copy usb to flash
make sure you change the boot variable
wr and reload
any issue post full boot process from console.
BB
12 Replies 12
balaji.bandi
Once it booted
copy usb to flash
wr and reload
BB
Thanks for the reply! How do I change the boot to variable? What is the command?
Can you post the boot process to understand is the switch booted as expected and have
Switch#
and can you post below output to suggest better
# dir
BB
I do not have the # I have switch:
 switch:  <--- here boot from USB as you did before
 Capture all boot process and post here as an attachment.
once booted successfully you get
 > en
switch#
post below output.
#dir
BB
The switch actually boots up from the USB with the correct/desired config file.
I will capture the dir# info tomorrow.
All the help is great, wish you were at the system with me, lol.
glad all working as expected
let us know any further help required, if not mark as solution if this is fixed.
BB
also, it boot up in ( switch: ) after the the file was deleted. Comes up normal form USB boot
ok boot from USB with the image.
once you switch booted and have
switch#
post output of below
switch#dir
BB
So what is the exact model of the switch?
Leo Laohoo
What is the actual model of the 2960?
The reason why I'm asking is because you're forcing the switch to load an IOS that is meant for 2960C Compact switch and they may not be compatible.
We have many systems that are all the same, just one got jacked up. I copied the file off an exact same switch
I am by no means a network pro!!LOL
