C3750 DWDM
PAUL CHEN
Is is possible to have dwdm connectivity on the 3750 series switches ?
The only wdm sfp connector available for the 3750 is CWDM.
I was told that all you need is a Fiber GE connection on the Switch.
Any advice appreciated.
Paul
paolo bevilacqua
Hi, you would need an external device to do DWDM with a 3750. You can feed it with MM fiber GE as you mentioned.
