C3850 Keep getting Error
vinothmseh1
there is no configuration done on the switch and it's empty, after rebooting the device gets an error.
when i console only.
Logs:-
*Aug 31 14:32:26.089: %IOSXE-4-PLATFORM: Switch 1 R0/0: kernel: EDAC MC0: 1 CE DIMM 0 rank 0 bank 4 row 348 col 12598 on any memory ( page:0x0 offset:0x0 grain:0 syndrome:0x0)EDAC MC0: 1 CE DIMM 0 rank 1 bank 0 row 58622 col 14518 on any memory ( page:0x0 offset:0x0 grain:0 syndrome:0x0)
Mark Elsen
 - Probably a fatal hardware condition and the device needs replacement (RMA)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
what version of IOS Code running on the switch ?
Try to upgrade newwer code and test it.
BB
while upgrading I am getting the below error.
Logs:-
Booting...(use DDR clock 667 MHz)
Interface GE 0 link down***ERROR: PHY link is down
The "IP_ADDR" environment variable is not set.
flash:cat3k_caa-universalk9ldpe.16.12.07.SPA.bin: no such file or directory
Cannot open file flash:cat3k_caa-universalk9ldpe.16.12.07.SPA.bin
Interrupt within 5 seconds to abort boot process.
Reading full image into memory..........................................................................................................................................................................................................................................................................................................................................................................................................done
Bundle Image
Kernel Address    : 0x5377166c
Kernel Size       : 0x365c1a/3562522
Initramfs Address : 0x53ad7286
Initramfs Size    : 0x16b1b0a/23796490
Compression Format: mzip
Bootable image at @ ram:0x5377166c
Bootable image segment 0 address range [0x81100000, 0x81bffb30] is in range [0x80180000, 0x90000000].
File "flash:cat3k_caa-universalk9.16.06.01.SPA.bin" uncompressed and installed, entry point: 0x816e0310
Loading Linux kernel with entry point 0x816e0310 ...
Bootloader: Done loading app on core_mask: 0x3f
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
