Accessing NTP Server from another Subnet
Tom101
Still quite new to networking. This question has been bothering me for a while.
How do i access a NTP server that is on another subnet?
I have attached a screenshot of a basic configuration. SW1 and SW2 can access the NTP clock, but SW3 cannot since it is on a different subnet. How would I set it up so SW3 can access the NTP clock from the NTP server on network 192.168.1.0/24. No routes or VLANs have been set up.
you need to make SW2 a layer 3 switch. Check the revised file I attached.
9 Replies 9
the short answer is: SW3 needs IP connectivity to the NTP server, 192.168.1.3. Without that, it cannot get time from that server.
Thanks Georg. How can that be achieved? I understand that on L3 devices you can use IP Routes to connect different networks together, but how can this be setup with my current topology?
I also understand you can use ip helper addresses for DHCP. Can something be done similar here?
Thank you, that was really helpful. I was able to break down your configuration and learn from it.
balaji.bandi
how is your switch config between SW2 and SW3 ? is this Layer 2 or Layer 3 ?
If 2 different subnets, you need to have some routing place to reach from network to network.
or extendd 192.168.1.X VLAN to SW3 so it can get NTP Information NTP Server.
BB
Ok, so two L3 switches / routers would be a more suitable choice?
how do we bridge 2 Layer 2 networks, you need some router right?
BB
Leo Laohoo
The core switch synchronizes with the NTP server.
The PCs have DHCP Option 42 enabled and point to the core switch.
No ACLs needed.
alexcjuz
I've been changed your layer 3 switch's config, and add some default-gateway in other devices.
you can see in file.
