C3925 cannot get port forwarding to work to RDP
Michael Durham
Level 4
Level 4
I have Googled this quite bit and from what I have read, my configuration should work.  However, I am not able to connect to my Server from the Internet.
I can RDP to my server across the internal network with no problem, the server is 2003 and has NO firewall.  I moved the port from 3389 to 5959.  I open RDP and enter 192.168.70.200:5959 and can login.
When I try from the Internet using my static IP 166.166.16.16:5959 I do not get connected.  I have an un-managed IP/connection from Verizon so they are not blocking any ports.
I have a static IP address with Verizon 4G (yes cellular), there is no firewall on the system.  Here are my configs:
chat-script ltescript "" "AT!CALL1" TIMEOUT 20 "OK"
interface GigabitEthernet0/0.70
description "Data Network"
encapsulation dot1Q 70 native
ip address 192.168.70.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
no ip route-cache
ip tcp adjust-mss 1300
ip policy route-map clear-df
interface Cellular0/3/0
ip address negotiated
no ip unreachables
ip nat outside
encapsulation slip
load-interval 30
dialer in-band
dialer idle-timeout 0
dialer string ltescript
dialer watch-group 1
async mode interactive
pulse-time 0
interface Dialer0
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer string 123456
dialer persistent
dialer-group 1
no cdp enable
ip nat inside source static tcp 192.168.70.200 5959 166.166.16.16 5959 extendable
ip route 0.0.0.0 0.0.0.0 Cellular0/3/0 track 10
access-list 151 permit ip any any
dialer watch-list 1 ip 5.6.7.8 0.0.0.0
dialer watch-list 1 delay route-check initial 60
dialer watch-list 1 delay connect 1
dialer-list 1 protocol ip permit
nls resp-timeout 1
cpd cr-id 1
route-map clear-df permit 10
set ip df 0
line 0/3/0
script dialer ltescript
modem InOut
no exec
transport input telnet
rxspeed 100000000
txspeed 50000000
Any ideas?  Any debug commands to run?
6 Replies 6
Jaderson Pessoa
@Michael Durham Hello,
insert command in bold below and test again.
interface Dialer0
ip nat outside
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer persistent
dialer-group 1
no cdp enable
Jaderson Pessoa
*** Rate All Helpful Responses ***
That did NOT fix the issue. I went to https://www.yougetsignal.com/tools/open-ports/ and entered my public IP address and port 80.  It came back as port 80 is OPEN.  Then I tested port 5959 and it comes back as CLOSED.
We do not have a firewall set up and Verizon is not blocking any ports so no idea what is closing the ports.  I also tested port 43, 21, and others, they tested CLOSED too.
your nat config is wrong.
ip nat inside source static tcp 192.168.70.200 5959 166.166.16.16 5959 extendable <<< your NAT
ip nat inside source static tcp 192.168.70.200 3389 166.166.16.16 5959 extendable <<< new as it
Jaderson Pessoa
That is not the solution. As I stated above, I can RDP to my server across the internal network with no problem, the server is 2003 and has NO firewall. I moved the port from 3389 to 5959. I open RDP and enter 192.168.70.200:5959 and can login.
is this the full configuration ? It looks like either some stuff has been omitted in your output, or some stuff is redundant. Either way, I have marked some lines (in bold) to be removed/changed, try if that makes a difference (it basically strips your config to the bare necessities):
ip nat inside
--> ip route-cache
--> no ip tcp adjust-mss 1300
--> no ip policy route-map clear-df
no ip unreachables
ip nat outside
encapsulation slip
load-interval 30
dialer in-band
--> no dialer watch-group 1
pulse-time 0
--> no interface Dialer0
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer persistent
dialer-group 1
no cdp enable
ip nat inside source list 1 interface Cellular0/3/0 overload
--> ip route 0.0.0.0 0.0.0.0 Cellular0/3/0
access-list 1 permit 192.168.70.0
nls resp-timeout 1
cpd cr-id 1
--> no route-map clear-df permit 10
set ip df 0
line 0/3/0
modem InOut
no exec
rxspeed 100000000
txspeed 50000000
Most of the commands that you are asking me to remove are needed.  We use Verizon cellular 4G as our internet source and those commands are necessary to get Verizon to work.
