Router 4321
MAGagnon
Hello
I just bought a 4321 router to replace my RV042. By connecting on the router I realized (with horror) that the configuration is done by CLI, I thought I was back in the 80s. I am not a
routers specialist but I understand what they do how do basic configuration.
Is it possible to have a visual version to configure the router like what I had for the RV042?
Giuseppe Larosa
Hello
So I have been in the 80s in last 22 years and I didn't know. Thanks for this moment of LOL !
Some sort of Cisco Network Assistant or Cisco Professional GUI should be available to perform basic setup.
Edit
I apologize the question is not trivial at all.
the Cisco Professional is in end of sale
https://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/configuration-professional/data_sheet_c78_462210.html
Cisco Network Assistant is described here
https://www.cisco.com/c/en/us/support/cloud-systems-management/network-assistant-version-6-0/model.html
Best Regards
Giuseppe
the GUI is available, you just have to add a few things to the configuration to enable it:
Configuring Web User Interface Access
http://www.cisco.com/c/en/us/td/docs/routers/access/4400/software/configuration/guide/isr4400swcfg/bm_isr_4400_sw_config_guide_chapter_011.html#task_AEE38B2E6B5A4971AFB1C06BA8382695
Leo Laohoo
GUI is available if the IOS was loaded in Install Mode.
Thanks for the answer, How i load the IOS ?
