C4507 VSS strange issue
Martynas
Recently I encountered strange problem at my work. In the network main routing is done by two c4507 switches stacked with VSS. All hosts on one of the switches can't reach subnet B, but this happens only on one of the c4507 in the stack, the other one doesn't have this problem. To understand it more clearly, I attached a picture
Also other strange thing is: while the host has a problem reaching subnet B, it doesn't have any problems reaching tens of other subnets, or the internet, but once again this problem can be solved by connecting the host to the other switch in VSS stack.
Tried to do packet capture and the traffic from host connected to C4507 SW1 arrives at the interface but doesn't go out the anywhere. I check dropped packet counters and they stay at 0.It feels like traffic trying to reach subnet B, just disapears if it's coming from hosts connected to C4507 SW1
I tried to reset switching cards with hw-module reset, but it didn't solved my problem. Next thing that comes to mind is rebooting the problematic switch in the stack. Obviously rebooting will be done during scheduled downtime. Is there anything else that can be done before trying to reboot? 
Any advice what do to, besides rebooting switch would be helpful.
EDIT: Solution was switch 1 reboot.
@Martynas wrote:
and will try to reboot the switch 1 chassis
Look, if there is a possibility for both chassis to be COLD reboot (completely turn it off and then on), do it.
18 Replies 18
Hello
sh switch virtual
sh switch virtual role
sh switch virtual link
Kind Regards
Paul
Hi Paul,
There's the output of the commands:
c4507-1#sh switch virtual
Executing the command on VSS member switch role = VSS Active, id = 1
Switch mode : Virtual Switch
Virtual switch domain number : 100
Local switch number : 1
Local switch operational role: Virtual Switch Active
Peer switch number : 2
Peer switch operational role : Virtual Switch Standby
Executing the command on VSS member switch role = VSS Standby, id = 2
Local switch number : 2
Local switch operational role: Virtual Switch Standby
Peer switch number : 1
Peer switch operational role : Virtual Switch Active
c4507-1#sh switch virtual role
RRP information for Instance 1
Valid Flags Peer Preferred Reserved
Count Peer Peer
TRUE V 1 1 1
Switch Switch Status Preempt Priority Role Local Remote
Number Oper(Conf) Oper(Conf) SID SID
LOCAL 1 UP FALSE(N ) 100(100) ACTIVE 0 0
REMOTE 2 UP FALSE(N ) 100(100) STANDBY 4909 9594
Peer 0 represents the local switch
Flags : V - Valid
In dual-active recovery mode: No
RRP information for Instance 2
Count Peer Peer
TRUE V 1 1 1
LOCAL 2 UP FALSE(N ) 100(100) STANDBY 0 0
REMOTE 1 UP FALSE(N ) 100(100) ACTIVE 9594 4909
Flags : V - Valid
c4507-1#sh switch virtual link
VSL Status : UP
VSL Uptime : 1 year, 17 weeks, 1 day, 10 hours, 17 minutes
VSL Control Link : Te1/3/1
VSL Status : UP
VSL Uptime : 1 year, 17 weeks, 1 day, 10 hours, 18 minutes
VSL Control Link : Te2/3/1
Hello
Is subnet B allowed over the trunk to via sw1, and is it in its vlan D/B ?
Sw1
sh int trunk
sh vlan bri
Kind Regards
Paul
The link between VSS stack and SW3 is port-channel(Updated the topology to represent it) and it has all needed VLAN. Also VSS switch routes traffic from subnet A from subnet B.
I did a packet capture and I could see the traffic coming from hosts connected to VSS SW 2 entering and going out of the stack, but as soon as the host is connected to VSS SW 1, it's traffic arrives to the stack, but never leaves it.
I don't think there's is any other explanation to this except hardware/software failure.
hmm, interesting issue,
the GW in VSS ?
the GW MAC address in Access SW point to ?
VSS is gateway to subnet A. It routes traffic from subnet A to subnet B.
nop,I dont think  that.
I will analysis the issue today
I'm pretty sure it's software problem.
Imagine two completely identical configuration ports, the only difference is one is on switch 1 and other is on switch 2 of VSS stack.
One port can reach subnet B, the other one can not. There is not other logical explanation.
We scheduled some downtime today, and will try to reboot the switch 1 chassis. Will let you know if it solves my problem.
Rebooted switch 1 and all hosts on subnet A were able to reach subnet B. Problem solved.
Thanks for help.
one Q, are the client that previous can connect after reboot can connect ?
https://www.cisco.com/c/en/us/support/docs/lan-switching/spanning-tree-protocol/11072-inter-vlan-11072.html
one issue that not relate to SW or HW,
you must analysis the issue and see where packet stop.
Leo Laohoo
Post the complete output to the command "sh version".
NOTE:  Erase the hostname of the switch.  Leave everything else alone.
c4507-1#sh version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500es8-UNIVERSALK9NPE-M), Version 03.06.06.E RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Sat 17-Dec-16 04:25 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.1(1r)SG5
c4507-1 uptime is 5 years, 6 weeks, 1 day, 13 hours, 9 minutes
Uptime for this control processor is 4 years, 40 weeks, 3 days, 14 hours, 50 minutes
System returned to ROM by SSO Switchover
System restarted at 16:27:53 EEST Tue Oct 17 2017
System image file is "bootflash:cat4500es8-universalk9npe.SPA.03.06.06.E.152-2.E6.bin"
Jawa Revision 3, RadTrooper Revision 0x0.0x41, Conan Revision 0x1449
Last reload reason: Stateful Switchover
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-X45-SUP8-E'
License Level: entservices Type: Permanent
Next reboot license Level: entservices
cisco WS-C4507R+E (P5040) processor (revision 2) with 4194304K bytes of physical memory.
Processor board ID xxxxxxxxxx
P5040 CPU at 2.2GHz, Supervisor 8-E
Last reset from Reload
16 Virtual Ethernet interfaces
192 Gigabit Ethernet interfaces
56 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
