07-26-2022 05:36 AM - edited 07-27-2022 09:14 AM
Recently I encountered strange problem at my work. In the network main routing is done by two c4507 switches stacked with VSS. All hosts on one of the switches can't reach subnet B, but this happens only on one of the c4507 in the stack, the other one doesn't have this problem. To understand it more clearly, I attached a picture
Also other strange thing is: while the host has a problem reaching subnet B, it doesn't have any problems reaching tens of other subnets, or the internet, but once again this problem can be solved by connecting the host to the other switch in VSS stack.
Tried to do packet capture and the traffic from host connected to C4507 SW1 arrives at the interface but doesn't go out the anywhere. I check dropped packet counters and they stay at 0.It feels like traffic trying to reach subnet B, just disapears if it's coming from hosts connected to C4507 SW1
I tried to reset switching cards with hw-module reset, but it didn't solved my problem. Next thing that comes to mind is rebooting the problematic switch in the stack. Obviously rebooting will be done during scheduled downtime. Is there anything else that can be done before trying to reboot?
Any advice what do to, besides rebooting switch would be helpful.
EDIT: Solution was switch 1 reboot.
Solved! Go to Solution.
07-26-2022 10:12 PM
Re-seat switch 1 supervisor card.
07-26-2022 10:41 PM
I thought about it but, it's the standby supervisor in the pair of two c4507. Would it still make sense to re-seat it?
07-26-2022 11:10 PM
Well, I'd re-seat Switch 1 first and then re-seat Switch 2 next.
That way, Switch 1 will get promoted to Active.
07-26-2022 10:45 PM
Hello
from vss and sw 3
sh port-channel sum
sh int port x
sh lacp neigbour
sh run int port x
sh run int x/x (physcal interface of the PC)
