C819 3G Roaming Issues
Sjoerd de Vries
We are currently testing a C819G-U-K9 3G router with a dutch Vodafone sim throughout Europe. And it continously seems to fail in the roaming process.
The output of the network status is then as follows:
Network Information
Current Service Status = Emergency Only, Service Error = MS identity unknown
Current Service = Invalid
Packet Service = None
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = ESP, Network = vodafone
Mobile Country Code (MCC) = 214
Mobile Network Code (MNC) = 1
Location Area Code (LAC) = 37302
Routing Area Code (RAC) = 0
Cell ID = 5115
Primary Scrambling Code = 246
PLMN Selection = Automatic
Radio Information
Radio power mode = ON
Current Band = WCDMA 2100, Channel Number = 10738
Current RSSI = -109 dBm
Band Selected = Auto
Number of nearby cells = 1
Cell 1
        Primary Scrambling Code = 0xF6
        RSCP = -110 dBm, ECIO = -11 dBm
Or:
Network Information
Current Service Status = Emergency Only, Service Error = None
Packet Session Status = Active
Country = ESP, Network = movistar
Mobile Network Code (MNC) = 7
Location Area Code (LAC) = 761
Routing Area Code (RAC) = 1
Cell ID = 31912
Primary Scrambling Code = 14
Radio Information
Current Band = WCDMA 2100, Channel Number = 10788
Cell 1
        Primary Scrambling Code = 0xE
        RSCP = -103 dBm, ECIO = -22 dBm
A complete reload then solves the problem and the router gets back online.
Are there any configuration that can be done so the router will reset the 3G connection on its own?
Or is this a common problem with roaming?
0 Replies 0
