C819-4G-LTE-G 4G connection don't come up
hencar
Level 5
Level 5
Cant get 4G connection to work in a C819 router.
Get this error message in the log:
*Mar  5 07:15:54.335: %PLATFORM-4-CELLULAR_MODEM_SKU_MISMATCH: Mismatch detected between installed modem Unknown modem on SKU type C819-4G-LTE-G. Expected modem for this SKU is MC7710
Anyone know how to fix it?
//HC
17 Replies 17
mziyada
Hi hencar,,
try to upgrade your firmware version to the release 3.5.29.2. let me know if you already have this version installed in your modem.
I already upgraded the router with version 15.4(3)M2 and the modem with version SWI9200X_03.05.29.02ap and it still does not work.
I got this error message when i run "sh cellular 0 all"
Warning: Mismatch detected between platform/module
and installed modem.Check system log for details
//Henrik
Hi Hencar,
I Just had the exact the same problem with a 1921
my router came with IOS 15.5.1T preinstalled
After reading this post I decided to downgrade the software even further so i installed 15.3.3M5(MD) which is a suggested release at the moment
The 4G card is recognized with that IOS!
Pim
try downgrade ios
I am having the eaxact same problem, I tried to downgrade to the version you mention aboe and others with no luck... did you manage to find a solution?
regards,
Panos
Did you downgrade to 15.3.3M5(MD) or 15.3.3M6(MD)?
That software is working for me!
Thank you,
c1900-universalk9-mz.SPA.153-3.M6 did the trick.., I thought I had allready tested but I was confused with 154-3
regards,
Panos
I have 1921 with EHWIC-4G-LTE-G. Every time I reboot my router, the 4G internet will not come up. But if I shut and unshut the cell 0/0/0, then the 4G will work.
I google it and find someone write a EEM script and it works for me.
event manager applet ResetCellOnBoot
 event timer countdown name ResetIn2Mins time 120
 action 1   cli command "enable"
 action 2   cli command "clear interface cellular 0/0/0"
 action 9   cli command "end"
 action 9.9 cli command "logout"
Hi Chanhkt,
Which Version of IOS are you using?
After using c1900-universalk9-mz.SPA.153-3.M6 the Modem is working but I can't get it to connect.
I can send sms messages but it doesn't get an IP, I am using the following config.
and tried both chat scripts
chat-script lte "" "AT!CALL" TIMEOUT 60 "OK"
chat-script HSPAPLUS "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
interface Cellular0/0/0
 ip address negotiated
 ip nat outside
 ip virtual-reassembly in
 encapsulation slip
 dialer in-band
 dialer idle-timeout 0
 dialer string HSPAPLUS
 dialer-group 1
 async mode interactive
line 0/0/0
 script dialer HSPAPLUS
 no exec
I am getting the following from debug
Mar 17 10:37:59.331: CHAT0/0/0: Attempting async line dialer script
Mar 17 10:37:59.331: CHAT0/0/0: Dialing using Modem script: HSPAPLUS & System script: none
Mar 17 10:37:59.331: CHAT0/0/0: process started
Mar 17 10:37:59.331: CHAT0/0/0: Asserting DTR
Mar 17 10:37:59.331: CHAT0/0/0: Chat script HSPAPLUS started
Mar 17 10:37:59.331: CHAT0/0/0: Sending string: AT!SCACT=1,1
Mar 17 10:37:59.331: CHAT0/0/0: Expecting string: OK.....
Mar 17 10:38:59.331: CHAT0/0/0: Timeout expecting: OK
Mar 17 10:38:59.331: CHAT0/0/0: Chat script HSPAPLUS finished, status = Connection timed out; remote host not responding..
also tried the clear interface cell 0/0/0
Thank you
Panos
Please give me:
sh cel 0 profile
and the profile config for cel 0 HSPAPLUS
regards Tom
ATHGW#sh cell 0/0/0 all
Hardware Information
Modem Firmware Version = SWI9200X_03.05.29.02
Modem Firmware built = 2014/06/16 17:56:29
Hardware Version = 1.0
International Mobile Subscriber Identity (IMSI) = 202010906029492
International Mobile Equipment Identity (IMEI) = 3XXXXXXXXXXXX
Integrated Circuit Card ID (ICCID) = 89300100120719546122
Mobile Subscriber International Subscriber
IDentity Number (MSISDN) =
Current Modem Temperature = 26 deg C
Profile Information
Profile password Encryption level: 7
Profile 1 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = i-amadeus
Authentication = None
  * - Default profile
 ** - LTE attach profile
br,
Panos
Give me the config:
beginning with
controller cel 0
like:
HSPAPLUS sim dataprofile 1 attach-profile 1 slot 0
- i will use LTE
rg
Tom
controller Cellular 0/0
track 1 ip sla 1 reachability
ip tftp source-interface GigabitEthernet0/0
ip nat outside
encapsulation slip
dialer in-band
dialer-group 1
control-plane
line con 0
line aux 0
line 2
line 0/0/0
no exec
line vty 0 4
exec-timeout 120 0
password 7 xxxxxxxxxxxxx
login local
transport input telnet ssh
regards,
Panos
pboot
Hi all,
I have two new C819G-4G-G-K9 with exact the same error message. (both have a MC7710)
Both are running:
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.4(3)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sat 25-Oct-14 07:36 by prod_rel_team
ROM: System Bootstrap, Version 15.2(2r)T1, RELEASE SOFTWARE (fc1)
VPN_HEERLEN uptime is 3 hours, 3 minutes
System image file is "flash:c800-universalk9-mz.SPA.154-3.M1.bin"
#show cellular 0 hardware
Modem Firmware Version = SWI9200X_03.05.24.00Aap
Modem Firmware built = 2013/11/01 21:34:04
Hardware Version = 10
International Mobile Subscriber Identity (IMSI) = 204080666314816
International Mobile Equipment Identity (IMEI) = 359470040276307
Integrated Circuit Card ID (ICCID) = 8931086113113999169
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) =
Current Modem Temperature = 0 deg C
PRI SKU ID = 9903047, PRI version = 01.00
Any solutions yet?
With kind regards.
Paulb.
