C819G-4G-V-K9 help (no ip address) Cellular0 is up (spoofing), line protocol is up (spoofing)
We recently purchased a C819G-4G-V-K9 for a remote site that has no ISP available.  I can't seem to get this working properly.  I can tell the cell portion is up and working becuase I can send the router a text message and I receive it on the router.  The cell 0 interface however, is not getting a dhcp address.  Below is my configuration:
hostname Router
boot-start-marker
boot system flash:c800-universalk9-mz.SPA.153-3.M.bin
boot-end-marker
aqm-register-fnf
no aaa new-model
memory-size iomem 10
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL1" TIMEOUT 60 "OK"
license udi pid C819G-4G-V-K9 sn FTX180680R8
vtp domain MobileCell
vtp mode transparent
controller Cellular 0
interface Cellular0
 ip address negotiated previous
 ip nat outside
 ip virtual-reassembly in
 encapsulation slip
 dialer in-band
 dialer string lte
 dialer-group 1
 async mode interactive
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface GigabitEthernet0
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0
 no ip address
 shutdown
 clock rate 2000000
interface Vlan1
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
dialer-list 1 protocol ip list 1
access-list 1 permit any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 script dialer lte
 no modem enable
line aux 0
 script dialer lte
 modem InOut
 no exec
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 stopbits 1
line 3
 script dialer lte
 modem InOut
 no exec
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
  Hardware is 4G WWAN Modem - Verizon Multimode LTE/eHRPD/EVDO RevA/Rev0/1xRTT
  Internet address will be assigned dynamically by the network
  MTU 1500 bytes, BW 9 Kbit/sec, DLY 100000 usec,
  Encapsulation SLIP, loopback not set
  Keepalive not supported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/10 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
     DCD=down  DSR=down  DTR=up  RTS=up  CTS=up
Router#sh ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
Cellular0                  unassigned      YES manual up                    up
FastEthernet0              unassigned      YES unset  down                  down
o1463050
Not sure if you solved your problem yet, but my Cell0 has a few extra lines. I also have a static IP, so it might not be exactly the same as yours.
interface Cellular0
no ip unreachables
ip nat outside
encapsulation slip
load-interval 30
dialer in-band
dialer idle-timeout 0
dialer string lte
dialer watch-group 1
routing dynamic
ip sla auto discovery
access-list 100 permit ip any any
dialer watch-list 1 ip 5.6.7.8 0.0.0.0
dialer watch-list 1 delay route-check initial 60
dialer watch-list 1 delay connect 1
dialer-list 1 protocol ip permit
Cellular0 is up, line protocol is up
  Internet address is xxx.xxx.xxx.xxx/32
  MTU 1500 bytes, BW 50000 Kbit/sec, DLY 100000 usec,
  Last input 00:00:00, output never, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 264
  30 second input rate 11000 bits/sec, 16 packets/sec
  30 second output rate 11000 bits/sec, 16 packets/sec
     1242186 packets input, 660512785 bytes, 0 no buffer
     1164618 packets output, 233386561 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
We did solve the issue.  Our local Verizon was using a different cell 0  profile name than what is shipped with this router.
