NAT overload issue with InterVLAN/Router on a stick
Eric Webber
I have a stacked pair of 3750's connected to a 2811 which is connected to a cable modem.  I also have a C6100 with each node NIC teamed to a cross-stack etherchannel trunk allowing all VLANs.  Each node is a Hyper-V host with the host management separated out by vNICs into VLAN ID's < 100 and guest OSE's tagged with ID's 100-200.  Everything ID <100 (except 10) is set to stay within the stack with 100-200 trunked to the 2811 for potential NAT overloading to the outside world.
From the router, I can ping the switch and its VLAN IPs, the ISP-assigned GW and 8.8.8.8.  I can even ping the guest on VLAN 200.  The guest can ping the router's IP but no further.  It looks as though NAT is set correctly so I'm really at a loss.  Any assistance would be much appreciated!
interface FastEthernet0/0
 description INTERNET
 ip address 74.A.B.C 255.255.255.248
 ip access-group INTERNET_DMZ in
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip flow egress
 ip nat outside
 ip virtual-reassembly in
 zone-member security Internet
 duplex full
 speed auto
 no cdp enable
interface FastEthernet0/1.200
 description DMZ
 encapsulation dot1Q 200
 ip address 192.168.200.1 255.255.255.0
 ip access-group DMZ_INTERNET in
 ip nat inside
 zone-member security DMZ
ip default-gateway 74.A.B.E
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip nat inside source list NAT_SOURCE interface FastEthernet0/0 overload
ip access-list standard NAT_SOURCE
 permit 192.168.200.0 0.0.0.255
 permit 172.16.100.0 0.0.0.255
 permit 172.16.110.0 0.0.0.255
 deny   any
ip access-list extended DMZ_INTERNET
 permit ip 192.168.200.0 0.0.0.255 any log
 deny   ip any any
2811A#sho ip nat stat
Total active translations: 4 (0 static, 4 dynamic; 4 extended)
Peak translations: 92, occurred 4d04h ago
Outside interfaces:
  FastEthernet0/0
Inside interfaces:
  FastEthernet0/1.200
Hits: 68730  Misses: 0
CEF Translated packets: 3429, CEF Punted packets: 62754
Expired translations: 19383
Dynamic mappings:
-- Inside Source
[Id: 12] access-list NAT_SOURCE interface FastEthernet0/0 refcount 4
Total doors: 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
2811A#
2811A#sho ip nat trans
Pro Inside global      Inside local       Outside local      Outside global
udp 74.A.B.C:58842 192.168.200.101:58842 8.8.4.4:53     8.8.4.4:53
udp 74.A.B.C.62:58842 192.168.200.101:58842 8.8.8.8:53     8.8.8.8:53
udp 74.A.B.C:61722 192.168.200.101:61722 8.8.4.4:53     8.8.4.4:53
udp 74.A.B.C:61722 192.168.200.101:61722 8.8.8.8:53     8.8.8.8:53
2811A#
2811A#sho ip access-lis
Standard IP access list NAT_SOURCE
    10 permit 192.168.200.0, wildcard bits 0.0.0.255 (7686 matches)
    20 permit 172.16.100.0, wildcard bits 0.0.0.255
    30 permit 172.16.110.0, wildcard bits 0.0.0.255
    40 deny   any (93 matches)
Extended IP access list DMZ_INTERNET
    10 permit ip 192.168.200.0 0.0.0.255 any log (2242 matches)
    100 deny ip any any (1153 matches)
Extended IP access list INTERNET_DMZ
    10 permit udp any eq domain any (28 matches)
    11 permit icmp any any (95 matches)
    20 permit tcp any any established (59 matches)
    100 deny ip any any log (1488 matches)
2811A#
cadet alain
first  do this:
int f0/0
 no ip access-group INTERNET_DMZ in
Then if it still doesn't work  post the full config because I don't see the Zone-based firewall policy.
Alain
cadet alain
first  do this:
int f0/0
Alain
The zones!  I had set them in CCP and forgotten all about them.  Much appreciated.
