Showing results forĀ
Search instead forĀ
Did you mean:Ā
C819G-4G-VZ-K9 Verizon 4G LTE Flapping
fdiedrich
Hi there,
We try to use a Cisco 819G 4G LTE ISR with a Verizon sim card. The 819G should be the backup for an existing cable connection. We configured it and are able to ping to the internet from the 819G. If we now try to use the backup from the internal LAN, the connection starts to flap about every minute or even seconds. Attached is the log when flapping and the current config.
We assume the connection could be dropped by Verizon because of sending packets they don't like (referring to this document, page 3, 7.a., Document). Maybe someone can help to figure out how to reconfigure the 819G as we don't know what to do next.
Thank you
Florian
Log
*Jan 23 09:21:44: %CELLWAN-2-BEARER_UP: Instance id=0, Default bearer (bearer_id=6) in Cellular0 is now UP
*Jan 23 09:21:46: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
*Jan 23 09:22:11: %CELLWAN-2-BEARER_DELETED: Instance id=0, Default bearer (bearer_id=6) in Cellular0 is now deleted.
*Jan 23 09:22:18: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
*Jan 23 09:22:29: %CELLWAN-2-BEARER_UP: Instance id=0, Default bearer (bearer_id=6) in Cellular0 is now UP
*Jan 23 09:22:31: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
*Jan 23 09:22:37: %CELLWAN-2-BEARER_DELETED: Instance id=0, Default bearer (bearer_id=6) in Cellular0 is now deleted.
*Jan 23 09:22:44: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
*Jan 23 09:22:55: %CELLWAN-2-BEARER_UP: Instance id=0, Default bearer (bearer_id=6) in Cellular0 is now UP
*Jan 23 09:22:58: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
*Jan 23 09:23:36: %CELLWAN-2-BEARER_DELETED: Instance id=0, Default bearer (bearer_id=6) in Cellular0 is now deleted.
*Jan 23 09:23:43: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
*Jan 23 09:23:54: %CELLWAN-2-BEARER_UP: Instance id=0, Default bearer (bearer_id=6) in Cellular0 is now UP
*Jan 23 09:23:56: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
*Jan 23 09:23:58: %CELLWAN-2-BEARER_DELETED: Instance id=0, Default bearer (bearer_id=6) in Cellular0 is now deleted.
*Jan 23 09:24:05: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
*Jan 23 09:24:16: %CELLWAN-2-BEARER_UP: Instance id=0, Default bearer (bearer_id=6) in Cellular0 is now UP
*Jan 23 09:24:18: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
*Jan 23 09:24:51: %CELLWAN-2-BEARER_DELETED: Instance id=0, Default bearer (bearer_id=6) in Cellular0 is now deleted.
*Jan 23 09:24:58: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
Config
Current configuration : 5331 bytes
! Last configuration change at 10:08:30 EST Mon Jan 23 2017 by admin
version 15.5
service timestamps log datetime localtime
hostname C819G4G
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ethernet lmi ce
clock timezone EST -5 0
clock summer-time EDT recurring
crypto pki trustpoint TP-self-signed-1113351855
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1113351855
revocation-check none
rsakeypair TP-self-signed-1113351855
crypto pki certificate chain TP-self-signed-1113351855
certificate self-signed 01
quit
no ip domain lookup
ip domain name ...
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid C819G-4G-VZ-K9 sn ...
object-group network net-3.238-ltetransfer
10.3.238.0 255.255.255.0
vtp mode client
username admin privilege 15 password 7 ...
controller Cellular 0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
no cdp run
interface Cellular0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer pool-member 1
dialer-group 1
async mode interactive
routing dynamic
interface FastEthernet0
switchport mode trunk
no ip address
interface FastEthernet1
description UPLINK to SWITCH
switchport access vlan 238
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
no ip address
interface Vlan238
ip address 10.3.238.254 255.255.255.0
ip nat inside
interface Dialer1
ip nat outside
encapsulation slip
dialer pool 1
dialer idle-timeout 0
dialer string lte
dialer persistent
dialer-group 1
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list nat-list interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip ssh version 2
ip access-list extended nat-list
permit ip host 10.3.238.253 any
deny ip any any
dialer-list 1 protocol ip permit
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
login local
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line 3
script dialer lte
modem InOut
no exec
rxspeed 100000000
txspeed 50000000
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
ntp server 10.3.254.254
end
I made a few changes to your config (marked in bold), give it a try and check if the link stops flapping.
I also took out the 'routing dynamic' from the cellular interface.
version 15.5
hostname C819G4G
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
quit
no ip domain lookup
ip domain name ...
ip cef
no ipv6 cef
vtp mode client
no cdp run
interface Cellular0
ip nat outside
encapsulation slip
dialer in-band
dialer-group 1
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
no ip address
interface Vlan238
ip nat inside
interface Dialer1
ip nat outside
encapsulation slip
dialer pool 1
dialer string lte
dialer persistent
dialer-group 1
no ip http server
ip dns server
ip nat inside source route-map BACKUP interface Dialer1 overload
ip ssh version 2
access-list 1 permit 10.3.238.0 0.0.0.255
route-map BACKUP permit 10
match ip address 1
match interface Dialer1
control-plane
line con 0
login local
no modem enable
line aux 0
line 2
no exec
transport input all
stopbits 1
line 3
script dialer lte
modem InOut
no exec
rxspeed 100000000
txspeed 50000000
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
6 Replies 6
how is the 819 cellular backup triggered ? With the current configuration, the link would always be up.
What is your primary link and how is it connected to the 819 ?
Hi Georg,
We use a Sophos UTM,  the cable uplink is the preferred one, if it fails/disconnects, the UTM switches to the 819G uplink automaticly. Switching to the other uplink works like a charm on the UTM, but as soon as traffic occurs on the 819G it starts to flap.
version 15.5
hostname C819G4G
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
quit
no ip domain lookup
ip domain name ...
ip cef
no ipv6 cef
vtp mode client
no cdp run
interface Cellular0
ip nat outside
encapsulation slip
dialer in-band
dialer-group 1
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
no ip address
interface Vlan238
ip nat inside
interface Dialer1
ip nat outside
encapsulation slip
dialer pool 1
dialer string lte
dialer persistent
dialer-group 1
no ip http server
ip dns server
ip ssh version 2
match ip address 1
control-plane
line con 0
login local
no modem enable
line aux 0
line 2
no exec
transport input all
stopbits 1
line 3
script dialer lte
modem InOut
no exec
rxspeed 100000000
txspeed 50000000
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
Thank you for your help, I'll reconfigure the 819G with your suggested lines. As I configure it remotely, it will need some time to test it again.
Anyhow, I'll let you know the result as soon as possible.
We did a test last friday and it seemed like it fixed our issues. A stable connection was established for over 15 minutes.
Again, thank you for your help!
you can try this command under Interface cellular0:
(config-if)# dialer idle-timeout 0
*please rate helpful replays*
