01-30-2024 12:45 AM
As the C8200 is the Replacement Product of the ISR series, we want to know if we can configure IPSEC without any DNA subscription renewal.
And what is the needed boot level Network-Essentials, Network-Advantage or Level Network-Premier ?
HM
01-30-2024 03:58 AM
look at this document: Cisco Catalyst 8300/8200 Series Edge Platforms Ordering Guide - Cisco
The Cisco Catalyst 8300 and 8200 Series Edge Platforms must be ordered with a mandatory Cisco DNA subscription license along with the chassis for both traditional routing and SD-WAN deployments
=> you cannot order without DNA subscription license
but if you do not use this, you do not need to renew -> select the shortest subscription period.
look at this post Catalyst C8200 DNA License Tier for Non IPSEC traffic - Cisco Community
for Network-Essentials, Network-Advantage or Level Network-Premier versus license comparison
01-30-2024 11:47 AM
Hello
" boot level Network-Advantage " then reload the rtr should enable ipsec , however if your vpn traffic throughput is expected to exceed 250mb then an hsec licence maybe required
05-15-2025 01:39 AM - edited 05-15-2025 01:40 AM
@paul driver I have a the below license in my cisco 8200 and my throughput seems to be too low.
License Entitlement Tag Count Status
network-advantage_10M (ESR_P_10M_A) 1 IN USE
dna-advantage_10M (DNA_P_10M_A) 1 IN USE
what are the possiblities to upgrade this to 1 gig throughput in ipsec vpn
