07-04-2019 01:35 AM
I'm looking to update the IOS on an 887VA (C887VA-K90) router. It currently has an IOS image "c880-universalk9.....". Looking at the latest available image all I can see are images that start "c880data-universalk9.....".
What is the differences, if any, in these images? I'm trying to be certain the image I have downloaded is the correct and most up to date for the 887VA.
Solved! Go to Solution.
07-04-2019 07:45 AM - edited 07-04-2019 07:48 AM
Hi @Dan Brook,
Platforms with SKU starting with CISCO (i.e CISCO881-K9) run the c880data-universal image.
Platforms with SKU starting with C (i.e. C881-K9) run the c800-universal-k9 image.
You have the latter.
Cheers.
07-04-2019 04:13 AM
can you post current verison : show version, what is the version you like to upgrade to ?
07-04-2019 06:14 AM
XXXXXXXX#sh ver
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.7(3)M, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 27-Jul-17 02:21 by prod_rel_team
ROM: System Bootstrap, Version 15.4(1r)T1, RELEASE SOFTWARE (fc1)
XXXXXXXX uptime is 5 days, 12 hours, 7 minutes
System returned to ROM by reload at 02:00:00 BST Sat Jun 29 2019
System restarted at 02:03:03 BST Sat Jun 29 2019
System image file is "flash:c800-universalk9-mz.SPA.157-3.M.bin"
Last reload type: Normal Reload
Last reload reason: XXXXXXXX
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C887VA-K9 (revision 1.0) with 488524K/35763K bytes of memory.
Processor board ID XXXXXXXX
1 DSL controller
1 Ethernet interface
4 FastEthernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
254976K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 C887VA-K9 XXXXXXXX
License Information for 'c800'
License Level: advipservices Type: Default. No valid license found.
Next reboot license Level: advipservices
I'd like to change to the latest available which I believe is: c880data-universalk9-mz.157-3.M4a.bin
Hi @Dan Brook,
Cheers.
03-21-2025 09:33 AM
ROuter
#sh vers
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.3(3)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 24-Sep-14 09:11 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
LON-IC-001385 uptime is 2 hours, 30 minutes
System returned to ROM by reload at 13:57:16 UTC Fri Mar 21 2025
System restarted at 13:58:02 UTC Fri Mar 21 2025
System image file is "flash:c880data-universalk9-mz.153-3.M4.bin"
I want to upgrade it to c800-universalk9-mz.SPA.154-3.M10.bin IOS.
But it doesn't work. HOw do I upgrade ?
As I need to run vrrp v3 and track on this router.
03-21-2025 04:25 PM
As per I know, this product is end of life, but if Cisco still offers IOS, you can download the upgrade in normal procedure.
03-21-2025 04:47 PM
What, exactly, does not work? Explain.
03-22-2025 12:19 AM
Hello @saurabh-shete ,
post
show inventory
if your device has part number that starts with Cisco you need to find a newer c800-data-universal if available. This is what @Hector Gustavo Serrano Gutierrez has reported in his post.
Hope to help
Giuseppe
