C887VA-W WAN dhcp problem
vesa19772
Dear Experts,
Logs of my 887 get filled with dhcp restart messages every two hours:
May 16 15:08:34: %DHCP-5-RESTART: Interface ATM0.1 is being restarted by DHCP
.May 16 15:08:44: %DHCP-6-ADDRESS_ASSIGN: Interface ATM0.1 assigned DHCP address xx.xxx.xxx.xxx, mask 255.255.248.0, hostname
I found from previous messages that adding rule to have udp 68 to ATM0.1 solved the issue:
ip nat inside source static udp 192.168.1.1 68 interface ATM0.1 68
But this doesn't help, I still get the messages. Also I've tried to add rules like:
class-map type inspect match-all DHCP_QUERY
 match protocol udp
 match access-group 101
policy-map type inspect Internet_to_Trusted
 class type inspect DHCP_QUERY
  inspect
 class class-default
  drop log
zone-pair security Internet_to_Trusted source Internet destination Trusted
 service-policy type inspect Internet_to_Trusted
access-list 101 permit udp any any eq bootpc
access-list 101 permit udp any any eq bootps
 ATM0.1 is like following:
interface ATM0.1 point-to-point
 description Outside WAN
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 zone-member security Internet
 atm route-bridged ip
 pvc 0/100
  encapsulation aal5snap
And following sh for dhcp give:
887#show dhcp server
   DHCP server: ANY (255.255.255.255)
    Leases:   266
    Offers:   133      Requests: 398     Acks : 133     Naks: 0
    Declines: 0      Releases: 0     Query: 0     Bad: 0
    Forcerenews: 0      Failures: 0
    DNS0:   xxx.xxx.xxx.xxx,   DNS1:  xx.xx.xx.xx
    Subnet: 255.255.248.0   DNS Domain: xxxx
887#show dhcp lease
Temp IP addr: xx.xxx.xxx.xx  for peer on Interface: ATM0.1
Temp  sub net mask: 255.255.248.0
   DHCP Lease server: xxx.xxx.xx.xx, state: 7 Renewing
   DHCP transaction id: 2BF
   Lease: 7200 secs,  Renewal: 3600 secs,  Rebind: 6300 secs
Temp default-gateway addr: xx.xxx.xxx.x
   Next timer fires after: 00:34:38
   Retry count: 1   Client-ID:
   Client-ID hex dump:
   Hostname: 887
I don't find dropped packets from log for 68 or 67 udp port. How can I troubleshoot this that is my router able to renew the IP address from ISP correctly? Despite of these messages, ip address stays the same. Your help is greatly appreciated.
0 Replies 0
