DC Output Voltage status: Warning - failure
milkboy33
Hi All,
   We're getting this error message when we run a 'show environment' command on our 3845 router:
SYS PS1 is present.
        Fan status: Normal
        Input Voltage status: Normal
        Type: AC
        Thermal status: Normal
We've checked online, but could not find any more information on this and would really appreciate any insight.
Thanks!
Tom
Reza Sharifi
Is the system working with no issues.  The DC output stat should be "normal"
from the 3800 troubleshooting document:
This is an example of the output of the show environment command for a Cisco 3845 router that has one AC power supply with IP phone power output installed:
Router# show environment
SYS PS1 is present
	Fan status: Normal
		DC Output Voltage status: Normal
		Type: AC
SYS PS2 is absent
AUX (-48V) PS1 is present
AUX (-48V) PS2 is absent
Fan 1 Normal
Fan 2 Normal
Fan 3 Normal
link:
http://www.cisco.com/c/en/us/td/docs/routers/access/3800/hardware/installation/guide/hw/38troub.html
Yes we have referred to that document already. Yes the router is up on the second power supply and no the document does not say anywhere what that Warning means, hence the reason I posted it up on forums to see if anyone can provide more insight.
Thanks.
I have this same issue and was wondering if you ever found a solution to this issue.  I still can not find anything out on the web regarding this error.
Thanks.
