C887VA-WD-E-K9 Memory Upgrade 512MB to 1GB FL-8XX-512U1GB
Luca Pecchiari
i have installed this licence:
StoreIndex: 4 Feature: MEM-8XX-512U1GB Version: 1.0
License Type: Permanent
License State: Active, Not in Use
Lock type: Node locked
Vendor info: <UDI><PID>C887VA-WD-E-K9</PID><SN>FCZ181492MM</SN></UDI>
License Addition: Exclusive
License Generation version: 0x8100000
License Count: Non-Counted
License Priority: Medium
As you can see it is not in use, and the router does not recognize the memory upgrade.
i tryed to run:
caoslady(config)#license feature MEM-8XX-512U1GB
but my ios c800-universalk9-mz.SPA.154-3.M10.bin does not have this command.
Please do you have any ideas?
Thank you
balaji.bandi
Can you post-the show version to look detailed
as per your model, you posted here is datasheet - since I do not have that model to confirm
Maximum DRAM
1 GB (non-WiFi model factory upgrade option only); WiFi model have fixed 512 MB
https://www.cisco.com/c/en/us/products/collateral/routers/880g-integrated-services-router-isr/data_sheet_c78-682548.html
BB
balaji.bandi
Maximum DRAM
BB
Hello, my model have the Wi-Fi. So that licence will DO NOTHING on my router.
The bad thing is that i requested to a reseller if this licence work.
thank you very much.
caoslady#sh version
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.2(4)M6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 19-Mar-14 20:07 by prod_rel_team
ROM: System Bootstrap, Version 15.1(4r)M, RELEASE SOFTWARE (fc1)
caoslady uptime is 27 minutes
System returned to ROM by reload at 11:05:25 DST Sat Sep 19 2020
System restarted at 11:06:59 DST Sat Sep 19 2020
System image file is "flash:/c800-universalk9-mz.SPA.152-4.M6.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C887VA-WD-E-K9 (revision 1.0) with 363596K/29619K bytes of memory.
Processor board ID FCZ181492MM
1 DSL controller
1 Ethernet interface
4 FastEthernet interfaces
1 Gigabit Ethernet interface
1 ATM interface
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco Embedded AP (s)
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 C887VA-WD-E-K9 FCZ181492MM
License Information for 'c800'
License Level: advipservices Type: Permanent
Next reboot license Level: advipservices
balaji.bandi
Thanks for the information, Coming to the main question, what exactly you trying to do here,?
What is the goal?  what did you ask the vendor to give you?
BB
My goal was upgrade the memody DRAM of the router from 512 M to 1G.
I asked to a certified seller if that licence will do that on my router, and they told me that the license will do this on my router.
From your answer i alredy asked for the refound of the license, or they are wasted moeny.
Thank You for your help.
