C887VA-WD-E-K9 VDSL firmware vectoring question
Luca Pecchiari
i have a C887VA-WD-E-K9 and i am planning to move the line from ADSL to VDSL2.
Now i run this (c800-universalk9-mz.SPA.157-3.M6.bin);
Firmware Source File Name
VDSL embedded VDSL_LINUX_DEV_01212008
Modem FW Version: 4.14L.04A
Modem PHY Version: A2pv6C039t.d24o_rc1
Basically i need to know if the VDSL firmware that is now loaded support Vectoring ( ITU-T G.993.5), if not can you point me to the right firmware please?
On a post i find out that "To support VDSL vectoring (ITU-T G.993.5) your VDSL (modem) firmware needs to be at least 38h, ie. you need upgrade" but i am not able to compare version...
Thank you
2 Accepted Solutions
looks like you need B2pvC038h3:
--> supports the following features:
• G.993.2 (VDSL2) protocol
– PTM and ATM mode
– Annex B over ISDN band plans
– Profiles supported: 8a/b/c/d, 12a/b and 17a
– US0
– Diagnostics mode/DELT
– Bitswaps, SRA and SOS/ROC
– FEXT Equalized UPBO
– Dying Gasp
– INM
– PhyR and G.INP (Framing Type 1)
– SRA/SoS+G.INP
– Virtual Noise
– G.Vector (G.993.5) and G.Vector Friendly (G.993.2 Annex Y)
– Alternate Electrical Length Measurement
5 Replies 5
balaji.bandi
Personally, I do not believe your model support that ITU (ITU-T G.993.5)
you can look the datasheet.
https://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/data_sheet_c78-613481.html
BB
Luca Pecchiari
i found this
https://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/datasheet-c78-734157.html
Where my model is listed and it seem that the ITU-T G.993.5 is supported by 38H, but i cannot understand what is the version to get of the firmware
– PTM and ATM mode
– US0
– Dying Gasp
– INM
– SRA/SoS+G.INP
– Virtual Noise
Luca Pecchiari
i dig a bit more and fint out that those release support it.
25-May-2016 VA_A_39t_B_35j_24m
12-Apr-2016 VA_A_39d_B_38h3_24h_1.bin
28-Jul-2015 VA_A_39h_B_38h3_24h_j.bin
31-Jul-2014 VA_A_39d_B_38h3_24h.bin
29-Jul-2014 VA_A_38q_B_38r1_24j.bin
01-Nov-2013 VA_A_38k1_B_38h_24g1.bin
may be someone will find this useful.
As they change the line i will post the firmware used.
Thank you all again
