C888-k9
bertrandcazal
I have a problem with a Cisco C888-K9
I can not manage the EFM part
the command controller DSL 0 does not work
13 Replies 13
which one doesn't work, the 'auto' or the 'pairs' ?
888K9(config-controller)# mode efm
888K9(config-controller)# dsl-group 0 pairs 0-1 efm-bond
888K9(config-controller)#dsl-group auto
i can't go to config-controller
i do
888K9#config t
Enter configuration commands, one per line. End with CNTL/Z.
888k9(config)#controller DSL 0
% Invalid input detected at '^' marker.
can you post the output of 'show controllers' and 'show version' ?
show version
ROM: System Bootstrap, Version 15.4(1r)T1, RELEASE SOFTWARE (fc1)
yourname uptime is 6 minutes
System image file is "flash:c800-universalk9-mz.SPA.153-3.M6.bin"
Last reload type: Normal Reload
Last reload reason: power-on
888K9#sh controllers ?
Async Async interface
E1 E1 controller internal state
FastEthernet FastEthernet IEEE 802.3
J1 J1 controller internal state
T1 T1 controller internal state
bri Show BRI controllers
wlan-ap Service module interface to embedded AP
| Output modifiers
the 888-9K has  a G.SHDSL WAN interface. There are no DSL controllers in your device. There is a BRI controller. I have a feeling you don't have a 888K9 but another model. Can you post the running config ? Typically, there should be a line in there like this:
controller DSL 0
mode atm
line-mode auto enhanced
dsl-mode shdsl symmetric annex B
HELLO
physically, i have a G.SHDSL WAN interface but that right i don't have dsl controllers
on the routeur it's branded C888
on the running config i don't have controller DSL 0
Is there an ATM interface at all ? In interface configuration mode on the ATM interface. do you get any DSL options ?
it doesn't work also with ATM
Current configuration : 5575 bytes
! Last configuration change at 08:12:35 UTC Thu Dec 29 2016 by cisco
version 15.3
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
crypto pki trustpoint TP-self-signed-232486529
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-232486529
revocation-check none
rsakeypair TP-self-signed-232486529
crypto pki certificate chain TP-self-signed-232486529
certificate self-signed 01
30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32333234 38363532 39301E17 0D313630 34323530 32353730
355A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3233 32343836
35323930 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
93283090 844F7677 67631488 A8EBCAB5 97FA7483 CDEFB221 D7B69A99 37F37AE0
FC3795A6 4C7D2933 9920648E 7D4A2F5E 4DC5C83C ACE3ABF5 B4D34FB6 B88639A3
2A66B9CB 497399B7 BAA56A11 D37146E5 35BB3013 07618F61 F97FDB65 7E764846
00030623 CB3C017D 99B9D31A 2D3AEF29 14856544 A8305B8B BE4F5D4E 165564F9
02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
23041830 1680148F B9DD4808 AC9DF1CF 037425D4 02453B2C 8D219E30 1D060355
1D0E0416 04148FB9 DD4808AC 9DF1CF03 7425D402 453B2C8D 219E300D 06092A86
4886F70D 01010505 00038181 003938D1 2D5C1078 EE5A5A98 80208AE1 DED7652F
2B10C5DD D15234D6 2CCAE34C E11590FD 784DA38D AD92DB30 C0CDCFB2 939E00FE
9D22BD74 1D138525 AA36B55B C0A9356D 73AE93D6 96E2001A E5C10276 8883179A
1E2B6DC9 40E55B06 B1F69FE0 2C832E95 84760CD7 88319FA2 47E8B8C8 EBE56C29
968D18B9 630E7FB7 1373D09D C0
quit
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.128
default-router 10.10.10.1
lease 0 2
no ip domain lookup
ip domain name yourdomain.com
ip cef
no ipv6 cef
license udi pid C888-K9 sn FGL2018202Z
username cisco privilege 15 secret 5 $1$.Hp7$LiHcoIdAAuri4PnjAqaEd.
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface wlan-ap0
description Embedded Service module interface to manage the embedded AP
no ip address
interface Vlan1
description $ETH_LAN$
ip address 10.10.10.1 255.255.255.128
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
no cdp run
access-list 23 permit 10.10.10.0 0.0.0.127
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
login local
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
you don't have a physical ATM interface, so nothing will work with DSL. Did you purchase this router from Cisco ? I has a BRI interface, which e.g. the Cisco 888SRST uses for voice backup.
i have a G.SHDSL WAN interface on my router
On the front of the router, i have some leds (CD,EFM,ATM,DATA)
i purchase the router from PICS TELECOM
this is what the running config should look like. There is a remote chance that your software doesn't recognize the ATM interface, I will check that...
controller DSL 0
mode atm
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
encapsulation hdlc
shutdown
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface Vlan1
no cdp run
is
888K9(config)#controller vdsl 0
available ?
no same error
